The reality is though, I'm not a competing lifter so the pause isn't a big thing. As long as I'm not bouncing the bar off my chest, just lowering and pressing in a controlled manner that's all that I care about.
I agree however pausing reps may assist with shoulder health... from what I've read
have you had a go at the Bamboo bar Markos has there?
had a quick muck around with it but that's about it... very odd to use... I imagine its similar to doing push ups on rings / TRX straps... building the stabilisers in your shoulders by pressing an instable object
I'm still trying to press a stable object correctly lol
nope from what I understand, Bench press is a test of shoulder health. You do need stronger shoulders/ scapular support to do it though, it's definately harder than not pausing.
Just curious as to whether any of you do rack pulls to improve your deadlifts?
Asking because my deadlifts are up at around 145kg, whereas my rack pulls are around 180-185kg.
It would seem the lower section of the lift is what I need to work on (my lock out is strong)
Any good ways to go about this?
I would have thought everyone would be stronger on rack pulls than deads, given it's only half the movement.
Deadlifts on a deficit, power cleans, should help with lower back.
Rows are upper back, but they do strengthen core and lower back at the same time. Seated row with lower back movement might be good.
Yeah I know it's always going to be the weaker part, this is why I want to work on it.
Once I improve that drive off the floor I'll be pulling some respectable numbers.
My gym doesn't have kettlebells so I'll give deficit deads a shot.
In my limited experience and understanding the floor part is sometimes mucked up by a combination of things. I am trying to remember it was a long time ago.
Most often I reckon getting the bar off the ground issues are 'the setup' and things like the approach based on your flexibillity and body mechanics.
When I started doing some deads again for that challenge, I had to start stretching my ankles to ensure I had enough dorsiflexion. I had bugger all straight away,to what is really needed. I still need to work on it if I ever want to play with something heavy.
Try these if you haven't already.
* Take all slack out of the bar hold before going for it. Stretch into tension by griping the bar and pulling up to point of tension a couple of times before the real lift. Crush the crap out of the bar. If there is any slack at all in the grip, then energy is lost as it's taken up (and the hips are probably going to leave the bar behind)
* Hips trying to come up too early as you try to 'heave' the bar off the ground.
* You need to 'push' yourself away from the floor and drive through the feet. (This is probably one of the most effective tips for getting the bar off the ground).
* Drive hips through the bar.
* Keep the tension in the back/lats not just the abbs.
I reckon posting a vid and someone like Markos can give you some pointers.
One thing I slacken on from time to time...but it makes a big difference...is starting with that bar pressed right up against your shins. The closer to your centre of gravity, the easier it's going to be to get that sucker off the floor. This means dragging the bar up your legs (grazing them on knurling haha) as you lean back and drive hard with the heels.
Every now and then I find the bar a couple of inches in front and I have to slap myself for it.
Mark ripptoe explains it well in starting strength.
Scapula should be directly over top of the bar, arms vertical, bar in the middle of your foot (which will usually find it resting against your shin/ankle). Pretty much what I recall his deadlift guide explaining.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
