Cheers. That's what I squatted at States earlier in the year (with wraps). I should squat around 230kg on Saturday which is a decent improvement seeing as I sat out for a few months with a bulged disk in my back.
I'll take 225kg on my second and depending on how it moves I may go for more than 230kg.
FULL RESULTS ProRawFive
80kg class
1. Greg Fraser - 79.6kg - 265/140/265 - 670kg
2. Les Grills - 74kg - 220/155/250 - 625kg
3. Allen Ozdil - 78.6kg - 225/135/250 - 610kg
4. Jason Chieng - 73.6kg - 215/130/235 - 580kg
5. Eddy Hady Darg - 79.2kg - 200/110/260 - 570kg
95kg class
1. Martin Nguyen - 93.2kg -300/175/320 - 795kg
2. Jesse Burrows - 95kg - 305/175/285 - 765kg
3. Joel 'Beeker' McCaughan - 93.8kg - 285/182.5/270 - 737.5kg
4. Adam Lam - 94.3kg - 245/142.5/240 - 627.5kg
110kg class
1. Daniel Green - 109kg - 385/237.5/380 - 1002.5kg
2. Jackson Murrie - 107.6kg - 350/195/310 - 855kg
3. Albert Ozdil - 106.6kg - 302.5/180/302.5 - 785kg
4. Conor Zyskowski - 98.9kg - 260/135/265 - 660kg
5. Lee Gamble - 98.6kg - 245/120/260 - 625kg
6. Nick Haralambopoulos - 106.5kg - 240/135/250 - 625kg
110kg+ class
1. Brandon Lilly - 149.4kg - 345/265/347.5 - 957.5kg
2. Luke Poli - 139.6kg - 330/215/310 - 855kg
3. Jack Pollard - 155.1kg - 317.5/205/320 - 842.5kg
4. Zachary Turner - 155.2kg - 350/220/270 - 840kg
5. Adam Mazzon - 123.6kg - 275/170/335 - 780kg
6. Daniel America 126.2kg - 285/185/300 - 770kg
7. Zoran Jankovski - 114.3kg - 280/160/285 - 725kg
Womens Results - Glossbrenner points
1. 466.82 - Iryna Piatrovich - [email protected]
2. 406.02 - Yolandie Weir - [email protected]
3. 369.03 - Heidi Stewart - [email protected]
4. 359.32 - Sussy Kollen - [email protected]
5. 354.27 - Alana Andrews - [email protected]
6. 353.68 - Rebecca Gleich - [email protected]
7. 347.42 - Jessica Lilly - [email protected]
8. 340.46 - Joanne Greagen - [email protected]
9. 336.46 - Melissa Knight - [email protected]
10. 329.45 - Vicki Jewson - [email protected]
11. 310.76 - Frances Fitzpatrick - [email protected]
Martin was set for 800kg, but then he missed his opening bench. Powerlifting is about winning, not PB's etc. Max erred on the side of caution because Jesse Burrows out squatted Martin. If Max had gone up to the planned 175kg second, and Marty missed it, he could have bombed. So 795kg it was, a 107.5kg PB from Nats.
If you guys remember, his total went up 2.5kg from States to Nats, so he decided to have Max coach him. Check out Marty's old squat and dead videos, check the difference in technique. Up until Nats Marty trained himself, now he wont wipe his ass unless Max tells him to.
Marty is going to lift in the 100's next year
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
