Cheers. That's what I squatted at States earlier in the year (with wraps). I should squat around 230kg on Saturday which is a decent improvement seeing as I sat out for a few months with a bulged disk in my back.
I'll take 225kg on my second and depending on how it moves I may go for more than 230kg.
FULL RESULTS ProRawFive
80kg class
1. Greg Fraser - 79.6kg - 265/140/265 - 670kg
2. Les Grills - 74kg - 220/155/250 - 625kg
3. Allen Ozdil - 78.6kg - 225/135/250 - 610kg
4. Jason Chieng - 73.6kg - 215/130/235 - 580kg
5. Eddy Hady Darg - 79.2kg - 200/110/260 - 570kg
95kg class
1. Martin Nguyen - 93.2kg -300/175/320 - 795kg
2. Jesse Burrows - 95kg - 305/175/285 - 765kg
3. Joel 'Beeker' McCaughan - 93.8kg - 285/182.5/270 - 737.5kg
4. Adam Lam - 94.3kg - 245/142.5/240 - 627.5kg
110kg class
1. Daniel Green - 109kg - 385/237.5/380 - 1002.5kg
2. Jackson Murrie - 107.6kg - 350/195/310 - 855kg
3. Albert Ozdil - 106.6kg - 302.5/180/302.5 - 785kg
4. Conor Zyskowski - 98.9kg - 260/135/265 - 660kg
5. Lee Gamble - 98.6kg - 245/120/260 - 625kg
6. Nick Haralambopoulos - 106.5kg - 240/135/250 - 625kg
110kg+ class
1. Brandon Lilly - 149.4kg - 345/265/347.5 - 957.5kg
2. Luke Poli - 139.6kg - 330/215/310 - 855kg
3. Jack Pollard - 155.1kg - 317.5/205/320 - 842.5kg
4. Zachary Turner - 155.2kg - 350/220/270 - 840kg
5. Adam Mazzon - 123.6kg - 275/170/335 - 780kg
6. Daniel America 126.2kg - 285/185/300 - 770kg
7. Zoran Jankovski - 114.3kg - 280/160/285 - 725kg
Womens Results - Glossbrenner points
1. 466.82 - Iryna Piatrovich - [email protected]
2. 406.02 - Yolandie Weir - [email protected]
3. 369.03 - Heidi Stewart - [email protected]
4. 359.32 - Sussy Kollen - [email protected]
5. 354.27 - Alana Andrews - [email protected]
6. 353.68 - Rebecca Gleich - [email protected]
7. 347.42 - Jessica Lilly - [email protected]
8. 340.46 - Joanne Greagen - [email protected]
9. 336.46 - Melissa Knight - [email protected]
10. 329.45 - Vicki Jewson - [email protected]
11. 310.76 - Frances Fitzpatrick - [email protected]
Martin was set for 800kg, but then he missed his opening bench. Powerlifting is about winning, not PB's etc. Max erred on the side of caution because Jesse Burrows out squatted Martin. If Max had gone up to the planned 175kg second, and Marty missed it, he could have bombed. So 795kg it was, a 107.5kg PB from Nats.
If you guys remember, his total went up 2.5kg from States to Nats, so he decided to have Max coach him. Check out Marty's old squat and dead videos, check the difference in technique. Up until Nats Marty trained himself, now he wont wipe his ass unless Max tells him to.
Marty is going to lift in the 100's next year
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
