Cheers. That's what I squatted at States earlier in the year (with wraps). I should squat around 230kg on Saturday which is a decent improvement seeing as I sat out for a few months with a bulged disk in my back.
I'll take 225kg on my second and depending on how it moves I may go for more than 230kg.
FULL RESULTS ProRawFive
80kg class
1. Greg Fraser - 79.6kg - 265/140/265 - 670kg
2. Les Grills - 74kg - 220/155/250 - 625kg
3. Allen Ozdil - 78.6kg - 225/135/250 - 610kg
4. Jason Chieng - 73.6kg - 215/130/235 - 580kg
5. Eddy Hady Darg - 79.2kg - 200/110/260 - 570kg
95kg class
1. Martin Nguyen - 93.2kg -300/175/320 - 795kg
2. Jesse Burrows - 95kg - 305/175/285 - 765kg
3. Joel 'Beeker' McCaughan - 93.8kg - 285/182.5/270 - 737.5kg
4. Adam Lam - 94.3kg - 245/142.5/240 - 627.5kg
110kg class
1. Daniel Green - 109kg - 385/237.5/380 - 1002.5kg
2. Jackson Murrie - 107.6kg - 350/195/310 - 855kg
3. Albert Ozdil - 106.6kg - 302.5/180/302.5 - 785kg
4. Conor Zyskowski - 98.9kg - 260/135/265 - 660kg
5. Lee Gamble - 98.6kg - 245/120/260 - 625kg
6. Nick Haralambopoulos - 106.5kg - 240/135/250 - 625kg
110kg+ class
1. Brandon Lilly - 149.4kg - 345/265/347.5 - 957.5kg
2. Luke Poli - 139.6kg - 330/215/310 - 855kg
3. Jack Pollard - 155.1kg - 317.5/205/320 - 842.5kg
4. Zachary Turner - 155.2kg - 350/220/270 - 840kg
5. Adam Mazzon - 123.6kg - 275/170/335 - 780kg
6. Daniel America 126.2kg - 285/185/300 - 770kg
7. Zoran Jankovski - 114.3kg - 280/160/285 - 725kg
Womens Results - Glossbrenner points
1. 466.82 - Iryna Piatrovich - [email protected]
2. 406.02 - Yolandie Weir - [email protected]
3. 369.03 - Heidi Stewart - [email protected]
4. 359.32 - Sussy Kollen - [email protected]
5. 354.27 - Alana Andrews - [email protected]
6. 353.68 - Rebecca Gleich - [email protected]
7. 347.42 - Jessica Lilly - [email protected]
8. 340.46 - Joanne Greagen - [email protected]
9. 336.46 - Melissa Knight - [email protected]
10. 329.45 - Vicki Jewson - [email protected]
11. 310.76 - Frances Fitzpatrick - [email protected]
Martin was set for 800kg, but then he missed his opening bench. Powerlifting is about winning, not PB's etc. Max erred on the side of caution because Jesse Burrows out squatted Martin. If Max had gone up to the planned 175kg second, and Marty missed it, he could have bombed. So 795kg it was, a 107.5kg PB from Nats.
If you guys remember, his total went up 2.5kg from States to Nats, so he decided to have Max coach him. Check out Marty's old squat and dead videos, check the difference in technique. Up until Nats Marty trained himself, now he wont wipe his ass unless Max tells him to.
Marty is going to lift in the 100's next year
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
