Thanks peeps, well and truly earned these extra few kgs
Leesh: I'm not sure to be honest, my head never used to move. Since I revised my technique, letting the bar sink right into my abdomen, my head just kind of wants to come up. I'm also not arching as hard and I've put my feet further out in front rather than trying to tuck them underneath me as much. I seem to be able to drive better with my legs this way. I think this style is better for raw benching. The extreme arch/bringing your belly up to meet the bar style is better suited to equipped lifting I think. It shortens the ROM but makes it hard to generate speed off your chest.
I basically tried to copy Dan Green lol
Havent been here for a while, been busy sorry. Opened up PTC's in Canberra, Eltham late last year, now have Port Melbourne and Rowville opening shortly, followed by Bondi.
Also have another couple in the early stages.
In 2 weeks we will be hosting the GPC Vic Titles at PTC, around 90 lifters over 3 days on the long weekend, March 8,9,10
Liters are all progressing, check this out
175? I'm all for supporting people but you're dreaming if you think there is a 175 to come after that 145.
That looked like a proper struggling max to me.
Can't see him gaining 30kg in 1 year.
Yes I was 'supporting' 145 is great work. 175 is significantly more 20% more.
However, I don't believe it's impossible. Just depends on what you commit to. Think of it as 15 little kilos a side. or in one year 2.5kg improvement a month. Thats 2x 1.25kg plates. Take the challenge Nick ha ha... you know you want 175kg!
haha yep it would be nice!
Motivation for lifting is waning at the moment. Injuries have taken the fun out of it so I'm trying to heal up as much as possible so I can make a run at GPC Nats. Work is has also really ramped up and that's the priority at the moment.
I'm going to run a modified broken man program into Nats. Heavy deads will be kept to a minimum (every 2-3 weeks) and I'm going to do a lot of lighter stiff legged deads. Squatting will become the priority and I'll bench as much as my shoulders let me. Shoulders were great for ages but the left one is now very inflamed.
I've been playing a lot of basketball recently and really enjoying it. It doesn't take the full mental/physical commitment of powerlifting and I've been doing it for so long it comes so naturally... definitely done my 10,000 hours with a basketball in my hands lol
I get very competitive so sitting on the sidelines watching others hit PBs is hard for me. I don't mind if I'm not the best but I love to compete.
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
