Hi Everyone,
Curious as to the availbility of a Bayside Blue R34 GTR Vspec II Nur.
Trying to gather how often they go through auction and what one would be expected to pay, landed and complied in AUS. Stock or mild modifications and high grade as preference.
Also if anybody knows how many of these were actually made?
If anybody has access to past auction history in japan to get a rough estimate on cost it would be great help.
Thanks.
You looking to upgrade or just want a twin to keep the other one happy? haha
Im guessing your privy to this site?
http://www.japaneseusedcars.com/auction/auctions_results.htm
you can go through past sales on there, but the records are only a few month old.
I had a quick scan through and the last nur sold through there was a pearl white mspec nur for a touch under 5mil.. Roughly 60k..
so would think a good example would be around 80k imported etc..
Hope that helps.
Cheers,
Anthony
^^^ ...which still makes Huy's pearl black VS2 Nur in WA look appealing :)
I'm aware and empathise that the money bracket is still very high for most people's pockets.
Heck, I waited for 3 yrs to be able to afford my black non-v-spec R34 GT-R
We must also be aware that production numbers of all R34 GTRs was very low compared to other GTRs.
And thus, Sum Insured values of several VS2 Nurs still sit just under $100K
Just a quick recap, mine imported from japan 2 years ago I paid just under 85k. Was a grade 4.5 only because the k's were over the limit of a grade 5 but still were low.
Mine was pretty much stock besides exhaust and mines rom.
Insurance companies are definitely still offering awesome agreed values. SS8 gohan can vouch for that. Mine stands at 95k now with my new policy about a month ago.
N1's are a six digit hit..well from what I've seen.
I'm guessing that buying a bayside blue Nur will be like buying the purple Z-tune. I'm sure they exist but they will be so sought after and rare that it will probably cost you over $100K. And with your attention to detail (a good attribute to have) you might be waiting a while.
Another colour perhaps?
going on the results the j-spec search pulled up, there's been two Blue Nur's sold (i don't know how far back the results look)
3.3mil for a 100K km R grade
a hefty 5.5mil for a 23K km 4.5 grade
  • 1 month later...
Grade 5 R32 GTR going through auction soon....
Might be one for the collectors. Id snap this one up if I had the money.
http://www.j-spec.co...NE-3055161.html
$18,700 AUD starting price... and 8000km wow. Genuine kms on a 1994 that's crazy. Wonder what it ends up selling for.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
