They do go together quite nicely; if anything I think a 600mm x 300mm core is a bit too big, probably about 600mm x 220mm would be spot on.
The other thing is; they can be had for as little as $580 now (free delivery) and the core is excellent. How much cheaper would your kits be?
below $450 del.....will have to recover smaple cost etc.
When I have R33 kits they are below $300
Core works fine....I have 450hp thru mine
SAU store coming in a couple of months
I could run 500hp without a cooler, it isn't the flow we are worried about but the efficiency of the cooling and the pressure drop over the core. Bar and plate I assume?
