Hi guys I'm pretty sure I need to rebuild it but I thought it worth asking the question. Last week I was about to race at Sydney dragway but I thought maybe I should do a compression test as I hadn't done one since fitting turbos. Cyl 1 to 5 were 150psi and #6 was 100psi wet or dry, the engine had been run that day but wasn't at operating temp. It doesn't use oil and still goes as good as it did at the skyline drag day where it ran 12.1 at 118mph. So I'm wondering if there is another test? I disconnected the cas and turned it over to listen for any difference while cranking but it sounded the same on each cylinder. Before I changed turbos I also attended a Wednesday night where the coil packs gave up and that's the only time I can think of anything actually going wrong with the car, but since then it's been dyno tuned and done at least 10 passes, is that possible with one cylinder 50psi down? Or am I just clutching at straws and need to rebuild it ?
Scott
https://www.sau.com.au/forums/topic/407845-rb26-compression-question/
  • 3 months later...
Hi guys just a quick update I decided to do hot compression test to see if there was any improvement and I did #5 and got 145 and #6 and got just over 140 with both I did for above 10 secs on starter I didn't bother checking the others as previously on the cold test they were even, so what does this mean? I'm looking at installing my -5s and 1000cc injectors and e85 but I don't want to waste time if the engine needs to come out, any opinions are appreciated. Scott
Hot dry test 145 and 140psi? Seems like a tired engine....boost it up should be right ! Haha
if he had some aftermarket cams, 140psi might be perfectly normal, and now there close in comparison compared to the original 50psi difference in number 6, and doing 12 second quarters it must be pretty healthy..
If your worried its the cam timing, mark where the cams are ATM. Than move them both back to 0 test the comp and see if there's a diffrence.
Than just set the cams back to the marks you made before you drive the car again.
Sorry I meant cam gear adjustment it has hks gears and its never been changed since it was tuned more than a year ago so I have no reason to think that has anything to do with it, it has 290kw at the rears but was limited due to afms still being stock but he said it made the power very easily,
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
    • Welcome to SAU, looks like you've picked up a nice one! Any plans to spend more money that you have on it until you hate it?
    • Also I cut away the top metal that was bent as there's no way I could have gotten it level and the rust stopped. I can also see clean metal under the windscreen. So it looks like this is the extent of it. The lower metal here is also strong.
    • Is this ok and then I don't need to patch the holes? Or is it not as good as separate fibreglass repair as well?  https://www.supercheapauto.com.au/p/septone-septone-glass-fibre-filler---500g/3151.html#q=Filler&lang=en_AU&vid=itBd4yPRKxscpBbIMOhvMg%3D%3D&start=10
