I did search and surprisingly didn't find anything conclusive .
Want aftermarket or even OE GTR radiator for a GTS25T . I'm not interested in cheap only effectiveness .
I looked into ARC HPI Evolve Koyo and there is someone else here fabricating better radiators but can't think of their name .
Things I need to know are how much core dept makes a worthwhile difference and does it get difficult mounting the std shroud on deeper cores .
Also prefer the minimum number of rows as in 1 is better than 2 and 2 is better than 3 . Ages ago I bought a Koyo replacement R32 GTR radiator and it was interesting in that it had 1 deep row of tubes .
I mentioned OE or equiv R33 GTR radiators because I'm guessing they had deeperer cores than the RB25 powered R33s .
For the record my 96 GTS25T has its original radiator and its just about to click over 100k , those composite tanks don't last forever and I've seen them fail on other cars sometimes damaging the engine . Also I'll end up on a chassis dyno in the not too distant future and I don't want cooling issues , not that I have any ATM .
I bought a genuine thermostat because my engine takes its time warming up and the temp drops on long downhill stretches in cool weather . I suspect its the original one and not seating/sealing properly when closed .
Also water pump was changed with genuine at 90k with the cam belt etc .
Thanks in advance , cheers A .
https://www.sau.com.au/forums/topic/408488-aftermarket-radiator-r33-whats-good/
  • Replies 48
Racepace have their own tri-pass item which is roughly half the price of a PWR item from memory, and works just as good. Used on all their track cars, perhaps give them a buzz for a quote.
I would have gone one of these if it wasnt for the 6 week turn around time from the day I ordered. My radiator was cactus and I couldn't afford the car to be off the road for such a long period of time.
Koyo, top quality not cheap ebay stuff and very well priced at 500 considering the quality item your getting.
+1
I have a Twin core, 52mm Koyo radiator in my RB30DET making ~300 RWKW. Cooling system took a beating whilst on the dyno. After 1.5-2 hrs of solid hammering, the thing only once brushed 95°C. Quality is awesome and only a slight modification was required to the existing OEM mounts/brackets.
Sorry to thread hijak, but on this topic (radiators n quality/design etc), i bought an ebay essentially no-name brand 52mm aluminium radiator for my R33 GTST. It seems to work great and temp are stable and the heat really dissepates quickly from it. Also its a welded design, not glued so certainly seems strong too.
Is there any reason that ebay radiators are often bagged out? I mean i had to fiddle and mod the mounts a bit to get it to fit but apart from that it seems great...
I have a fleabay rad in my GTST and it does the trick but it had a pinhole leak in one of the welds wehad to fix, after we had installed it and found it dribbling out coolant.
definitely a lucky dip when it comes to ebay. some get good items, some get rubbish.
OEM rads handle quite a lot, but if yours looks old and brittle probably worth changing, but unless you're chasing big power the standard rad, fan + shroud does an excellent job.
For piece of mind you really cant go past SAU traders.
Its not were saying all ebay radiators or products in general or rubbish the point is when you buy off ebay 10 people might get a good one that works well and next person will get a dud so the quality consistency isnt as good. For example the asi ebay ones alot of people have had good success with them but if you want a part that you can be assured will be top quality and will perform better for harsh use it pays to go for a good brand.
I'm also in the same position in looking for an aftermarket aluminium radiator and the way I see it, you essentially have options that go up in price by a factor of 2.
You can get an ASI rad from fleabay for around $150. The upside is that it's cheap and does the job. The downside is that you might get a dud and start again (but from what I've heard and read, they let you keep the dud one and send you a new one no questions asked).
$150 x 2ish will get you a Mishimoto rad, which I've heard good reviews about and have a low fail rate. The downside is that you'll most likely have to order it from the US, so if there's any problems and in need of a swap, the postage will be the killer blow.
$300ish x 2 will get you a lower/mid spec Koyo rad. No need to say anything about the quality and positive ratings that people give. The downside is that it'll cost you a lot more, with some of the high end Koyo rad nearly reaching $900.
At the end of the day it's a question of quality vs quantity. Do you have the time to muck around if the china spec rad starts leaking (common problem) or do you want to 'set and forget' with a good brand with proven quality record, but it'll cost you big money as well.
Go Koyo. . .used them in all of my cars, recommend them in our customer cars (Rx-7's) so you know they're up to the task. . .
Just swapped my OEM one out recently for the Koyo. . .oem had 130,000 km's. . .all is good. . .
After seeing Russman's ASI one buckle & bulge under circuit conditions (see pics his build thread)... I'd be debating the merits of a cheap radiator if you wanted it to last :)
Didn't realise there was a turnaround hehe, most I know usually plan ahead in that regard to change it (along with a few other mods at once type thing).
how did it buckle n buldge? just design/manufacturing issues or was it under pressure and torsion while in the car and at operating temp/movement?
Read the build thread - just pressure from being used under circuit conditions.
For $150... What do you expect it do anyway? Clearly being made with cheap quality.
true enough. cheers.
otherwise if anybody can answer this question on radiators. What is the deal with the number of cores, e.g. 'dual core' or more radiators and is it necessary?. I have no idea what my 52mm fleabay radiator is either..
Most of the cheapo ones are single pass and they cool less efficiently as a result.
Dual/Triple pass items cool better as the water spends more time in the radiator to actually cool (put and S on its side, and draw it on a radiator basically).
With my tri-pass cores, had two over 2 cars now - driving around on a 25 degree day I'd see temps around 70-73 degrees which is quite decent. Doing hill runs when ambient was 10 degrees or cooler night, temps would also stay under 80 which is pretty impressive (neither were Racepace ones for what it's worth, just decent tri-pass items)
ah ok. cheers for that run down. All makes alot more sense now :)
I havent been able to get my temps to budge off 72 as yet with my new radiator so seems to be doing its job. (thermofanned too, which dont come on much at all unless in stop start and when they do it pulls the heat out real quick)
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
