Stripping down my track r33, a lot of these parts are brand new.
Was close to being finished before i have decided on a different direction.
I have put everything at good prices, so don't be surprised if I don't want anything to do with lowballers
Can post a lot of things but WILL BE AT BUYERS EXPENSE!
Located in sydney
HKS 256/264 cams retaining vct
with HKS adjustable exhaust cam gear $500 very good condition
R33 RB25DETHead
Supertech valve springs
Supertech titanium retainers
Supertech valve stem seals
Supertech seats
Head machining including multi-angle valve job, oil gallery enlargement and decking, mild exhaust porting
This is all brand new, never been used, just test fitted.
$1000
RB25 Block
Good condition
Tomei oil restrictors
ARP headstuds
$250
Tomei 1.5mm headgasket $250
Apexi pod filter $20
New Z32 arm with tome plug $250
garret 3076r .63 turbo $1200
Tial 44m waste gate with screamer pipe $250
HKS cast manifold - machined flat $650
3" dump/front pipe $200
WIth new gaskets and studs
Will do the lot for $2000
Trust/Greddy 3.5inch titanium exhaust to suit r33 gtr/gtst $1000 - very good nick, very straight exhaust minimal bends
Greddy Inlet Plenum with
Q45 90mm throttle body $750
cat delete pipe $50
JJR coilpacks $100
HKS SSQ BOV $25
FUEL
Tomei 740cc injectors $600
New Sard Fuel pressure reg $100
Walbro intank pump $50
New Bosch 044 external pump with 1.5 litre surge tank $300
COOLING
Nismo intercooler $200
Alloy radiator $50
New Greddy remote coolant reservoir $100
HKS Type S oil cooler with thermostat $500
RB25 Gearbox $1000 with new nismo gearbox mount
Blitz/ORC twin plate clutch $900
Nismo braided clutch line $100
Nismo pivot ball $50
AME Tracer TM02 18x9.5 +22
Hankook RS3's 265's 85%
Hankook Z221 265's 90%
$3500 for the lot with those tyres.....if you know anything about how good these tyres are you'd know this is a good deal.
May separate
INTERIOR/ELECTRONICS
Racetech whr4009 seat/alloy side mounts $1000
RPM 3" Harness $50
OMP steering wheel with
Removable boss kit $150
Nismo leather gear knob $40
RB25 Apexi Power FC with h/c $900
Blitz DSBC $250
Braille No Weight battery $250
EXTERIOR
Carbon Headlight intake $150
Carbon F1 side mirrors $150
Aeromotions R2 carbon fibre self adjusting wing $2000
Will get pics up later on
mate probably a couple years, haven't done too many km's.
I change the plugs every 3000km's at the most, and when i do i clean and spray them with contact cleaner.
They are in very good nick
i have a build thread here which has a few pictures of random parts etc
http://www.skylinesaustralia.com/forums/topic/349246-33-gtst-streettrack-car/page__fromsearch__1
The shell will be for sale soon with all aftermarket suspension/kaaz diff and brakes also
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
