Well, after putting off several opportunities in the past im finally going to head to wakefield and have a go round the track at this weekends UAS track day.
I plan to drive my MR2 for fun and I was hoping that some of the more experienced track driving people here could provide any tips or info such as which lines to take or avoid, as well as anything else I should know.
Thanks guys
Nick
  • Replies 46
Sure... let me drive!
On a serious note.
Take it eaisy the first few sessions if not the whole day. work on finding a line slowly and remember that smoothness is what counts. Your gear selection is important... use a higher gear to start with and try and find a gear that works for "most" of the track. The less changes you have to make the better you will find where to go.
Look for the white edge of track lines... more importantly where they have been worn (discoloured) by tyres running over them. this is where "most" people drive and would be close to the correct line (everybody drives slightly different).
Try and take an experenced driver out with you as much as possible. not every time, but maybe every second or third session. and try for different experienced drivers if you can. (If I was coming down I would jump into the passengers/drivers(your car if you'd let me) seat and let you know what I know and hope that it helps.
Most important,
Enjoy yourself and drive the car home.
Dan.
haha like Dan said the most important bit is to drive home :(
I guess the most important thing before hand is make sure ur brakes are OK, put in nice new fluid...I guess you've done all that sort of this since it just landed.
With the track itself, Wakefields a great place to get into it.....not just a drag track with corners like Eastern Creek...its got a great mix. Obviously you take it easy for a few sessions until you get comfortable where the track goes and how your car reacts.
To get consistency and speed out of the car, you note points/marks/bumps etc on the track as points to turn in to corners or brake. Generally people on the track for the first time brake to early and not hard enough and turn in to the corner too early. But the easiest way to sort out lines is to take out a passenger who can give suggestions.
I guess the main thing is tho, unless you're a driving genius like wreckhead, don't get overconfident. Amazing how all the big offs happen in the afternoon sessions when people think they've got it sorted...and they're a bit tired...
Thanks Duncan - that was my theory, I consider myself a good driver on the road but I dont think that means jack on the track so I will work my way into it gradually.
Nothing like cheater tyres for my first drive though eh :(
What profile tyres are you running Nick?
I put my old 17" rims on to race and found them much more comfortable with the way they let you know where the limits of traction are as opposed to the 18's I normally run.
The tyres are sh!t quality and I'll be using them again on Sunday but believe it or not I felt safer knowing my tyres were the weak link because (obviously being my first track day) I was still learning the car - as you will be this weekend.
To clarify that; I'd prefer the tyres let go than anything else.
Hope this makes sense. I have a massive one days track experience to back me up here with all previous hard driving being FWD on dirt.
Hmmm we as it happens im now going to be running on the factory 14 inch alloys with some new tyres thrown on the back.
Will look into larger wheels and better tyres later down the track.
I expect a lot of fun on Sunday - the MR2 should resemble a go kart on the track due to its size
you will have heaps of fun! good onya nick for giving it a go!
sounds like the mr2 will be mauled by the fire breathing Zed's and R's on the day though?!? but, you'll have equal amount of fun regardless of the car you're in :thumbsup:
these vids will give you an idea of the track :)
from the outside:
http://www.skylinesaustralia.com/photopost..._and_franks.wmv
from the inside:
http://www.skylinesaustralia.com/photopost...franks_laps.wmv
and heres what NOT to do ;)
http://www.members.optusnet.com.au/[email protected]
Haha thanks Franky, I couldnt care less who I get mauled by. I want to get the track feel before taking the GTR out.
I havent done a single track day and even I can see that "Russ" drives like an idiot on the race track :thumbsup:
After my first experience at Eastern Creek (as short as it was before my master cylinder decided it wanted to make bubbling sounds) I found that Duncan's comments above would have to be the #1 mistake people make.
Witches hats were place at the 'turn in' the 'apex' and the 'exit point' of the main corners at EC and it was quite amazing how far you would have to dirve (straight ahead towards the edge of the track) before you have to turn in. The first few laps (with Dunan as my passenger) I felt as if I was going to run off the track and tried to turn in early (which if I was in the v8 Supercars it would have looked like I was "blocking" on every corner), it was quite surprising how far you have to stay out for before beginning to turn in.
Braking is not like normal street driving (slow and relaxed), when Duncan took me out I thought we were either gonna hit the car infront, run off the road or my brain was gonna slither out through my nose (heavy braking). Once your happy with your line and gear selection give the brakes a smooth yet heavier jab than what you would normally do on the road.
PS. I'm guessing the common gear at Wakefield is 3rd? with 4th down the straight? (won't reach 5th right? and 2nd being too slow for the top corners?)
This could be the start of some disagreements lol. Personally, all 3rd except breifly on the back straight, and on the front straight. With good corner speed and a quick car you might need 4th up the hill and back down to turn 8 (the fish hook). I don't use second in a RWD car....too much wheelspin and too close to needing to change up anyway....jsut leave it in 3rd and have plenty of boost as you come out of the corner :thumbsup:
I found the hardest habit to break was the turn in, i would always turn in too early, and probably still do.
When i drove an R33 i didnt touch 2nd gear around Wakefield, in my jigger though, when im really trying 2nd gear onto the straight, and on the tight left hander...its marginally quicker if i get out of the corners well, can be slower if i punt the thing sideways ...bu tdont normally do it as it menas the car has to rev a lot harder and i tend to wash off corner speed when i search for the lower gear.
Blitz - I went through my first track day experience earlier this year. All I can say is prepared to be hooked! lol
Anyways.... some advice from my first time out. Start off following someone who knows their way around the track. Preferably someone you could just beat powerwise normally but not someone you have to "slow down for" to follow. I kinda made this mistake on my first day - because when I finally decided that enough was enough and it was time to go forth and venture on my own I discovered my braking points were a whole lot different when I was at full flight! (LOL - my very first corner I went WAAAAYYYY off at turn 1 at Sandown! I had gone from being at about 180km/hr at the end of the straight when following a car to 240km/hr - didnt realise the braking distance was THAT big a difference for those speeds)
Also - speak to as many different people that have been at the track as possible for little tips. From my experience all the tracks have some little quirks or tips that can be handy for the non experienced. Don't know about Wakefield but Sandown has 3 corners where advice from others certainly helped me improve my times.
Regardless of lap times you will have heaps of fun. And then Im sure you will be dying to get the line out on the track!
Thats it... I propose a road trip to sanddown raceway... I can't get near 240 at EC!
/end hijack.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
