Hey everyone. I've recently purchased my first import, a 95 r33 gtst. Pretty much stock except someone down the line decided to put (yet to confirm) a giken twin plate clutch in it. I have absolutely no need for a clutch like this as I want to enjoy it on the street for now and think about the track later. (if anyone wants this clutch it will be for sale for cheap, obviously I'll check condition when it's out.)
So I'm considering putting in a new exedy HD clutch. Does anyone have any firsthand experience with this clutch?
Does the type of clutch depend on whether I have a push or pull type slave?
And lastly does anyone have any tricks for the getting the top bell housing bolts out? I've heard to just flex the engine on its mounts and use a million extensions?? Is there a less backyard way?
Thanks.
Btw I have searched but couldn't find specifics and if I'm in the wrong forum please move it.
https://www.sau.com.au/forums/topic/409004-clutch-shenanigans/
NPC
Why not just keep the twin? Guaranteed you will want power, and then at least you have a clutch that will hold it.
If you are concerned about not being able to drive the twin, then you just need more exposure. You will get used to it.
Even if you ride it like a bitch, you can replace it when it gives up.
Hadouken - yeah I do want more power but I'm only aiming for 260rwkw. And this clutch doesn't ride at all. I drove it for 2 weeks and still hate coming to red lights and hills. I'm definitely gonna change it.
Wolverine - thanks mate, do you have any advice for the other questions?
All the questions have been asked and answered many times which is why your thread isn't getting much of a response.
I would go for an NPC organic single but go to the right section and search/read there and you can make up your own mind regarding what will suit you.
I would take that twin out asap, its not for street use and its probably starting to stuff up your gearbox/driveline already.. i know my box feels/sounds a bit loosened up by the old 5puck that was in there for a few weeks only...
i have an exedy heavy duty, it will be good enough for 260kw, mines held 320kw, but maybe as well get the full face organic from NPC that holds 330kw
Yeah get rid of it. NPC or Exedy heavy duty. But if your going to pump out some power, go for the highest rated single plate clutch that retains drive ability.
My Missus' Chaser has a twin plate OS Giken clutch in it. I hate the damn thing in traffic and she struggles at the best of times with it. I keep telling her to change it as it has now destroyed the diff bushes and is killing the diff.
ive put an exey hd in looking to hold 320 atw. yours still good? Mind you no launches and tranck work for mine yet
I tried an Exedy cushioned button and it just melted when i tried to launch..... Clutches may last for a bit above their recommended power level but 1500kms later and mine was rooted!
It has held so far 2000kms and i think would last a long time as long as the clutch is out when the power goes down, but i must admit i did accidently not let the clutch out completely once or twice and i thought it was all over cause i could smell the burning
pretty bad for bout 5minutes and the pressure in the pedal kind of half went, so i will be getting a NPC 330kw clutch soon,
Edited by SliverS2
When you undo the gearbox mounts the weight of the box tilts it back... Just be careful not to crush anything or hit the fan etc.... Couple of extensions and your good to go.... If you have the breather bracket just remember which side it came off.
as above mate, NPC, the pedal is as light as stock too!
no need to change to larger slaves or stronger pivots, I was skeptical too, but was converted!
as for the top bolts,
use a jack, undo the gearbox mount bolts
lower on jack
then jack up the front of the motor so it stays at that level with the box off (helps getting it on too)
2x extensions 1x uni-joint should do the trick
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
