Ive been asked about turbo selection by mates who want to turbo their diesels.
2 have land cruisers with 4.2l diesels and another is rebuilding a 10.2l cat diesel to put in an old cruiser as an unlicensed farm car.
Does anything we use on our cars even come close to suiting a diesel? Both cruisers would rarely see 4000rpm but with the capacity difference they would only require a bit more air?
The guy with 10.2l cat engine would prefer twin setup. I'm unsure of the characteristic differences required between the 2 fuels and it got me curious.
Hoping someone has experience or could point me in the right direction.
Cheers
https://www.sau.com.au/forums/topic/409074-diesel-turbos/
And people put the HX35 onto 2.6ltr motors and then wonder why they are buckets of sh*t :D
it's not much chop on the 5.9 Cummins either, but that is the stock turbo so that's what went back on
though I think it's more the breathing setup on the truck more than the turbo, and the factory waste gate is 2 bar
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6527996
Yuh, petrol turbos and diesel turbos have different sizing of compressor relative to exhaust housing. Tends to make them not great matches when swapped.
Smaller compressor to turbine?
Would imagine 1.06 rear as they would be under load for longer and response is less of an issue?
Might see if Stao makes/modifies anything for the 4.2's
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528052
what about a 2.5 diesel turbo on a 2009 nissan navara? what could be done to give it a bit more go without massive expense like computers etc my bro just bought one.. :yes:
Edited by SliverS2
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528053
Mate put a 3076 anti sugre with a .82 rear on his GU Patrol TD42, highmount manifold and external gate. Thing is super responsive and makes about 180rwhp, which for a diesel is a lot.
I beleive Kando are starting to make some TD05 combo's aimed at Diesels, United Fuel injection in Perth are using some now.
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528067
Single cab in that goldy colour and lift kit?
One passes my place regularly and I can hear it spooling from miles away
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528076
Block wastegate hose :whistling:
lol.. i dont think he wants 30psi.. the later models have a variable vane turbo, maybe one of those would be a good upgrade.. answered my own question..
i wonder if one of the housings could be slapped on a skyline for extra response..maybe discopotato would know
so do diesel engines work well with gt30's?
Edited by SliverS2
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528100
try a 3" exhaust and a performance chip, 20-30% increase depending on quality of components
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528250
I was looking at some Gensets i worked around. Detroit Diesel 8.7L Inline 6. 200HP @ 1500RPM (Genset so locked to 1500RPM).
Wasn't able to see the ID tags on the turbo because of the turbo beanie that was wrapped around it.
But no wastegate, looked to be something similar sized to that of a GT30 with a huge exhaust housing - go figure its a diesel. Non water cooled core. I did see the compressor wheel on one when the engine was getting a service and it had quite a small compressor wheel.
After going through all the engine parameters on the Genset control unit, i cam accross Boost pressure. Boost pressure was holding at a constant 0.1 - 0.2 Bar. Which is bugger all. I believe in this instance these engines are turbocharged purely to get more efficiency out of them.
Another story, a friend of mine is currently working out which turbo to replace his current one on his 5L (3 Litre) Hilux engine. Currently has a TD04-13G. According to MTQ and Adelaide turbo services keeping that Turbo is ideal for that enigne.
Bit of a story there but maybe some of it was useful :whistling:
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528384
I've worked on 6L- 60L gensets and they all ran 15-25psi. Sounds like yours wasn't loaded up
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528401
Diesel exhaust temps are somewhat lower than high strung petrols.....so the variable vane mechanisms usually shit themselves fairly quickly when misapplied (ie used on petrol). Only Porsche and a couple of others have gone to the effort of engineering variable vane petrol engine stuff that can handle it.
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528409
That was with 70% Load. I thought the exact same thing when i first looked at it. Then read the screen three times, and yes very low boost pressure. Its exactly the same when the Gen sets are unloaded as well.
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528414
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
