  • Replies 72
Posted Images
There's always the "personalized" plate,
letter letter number number number. My Vdub has LO247 due to its low to the ground always haha. Wanted RB 025 or similar for the stag but she was taken. Might try for NE025
Wasn't there a Porsche getting around town with the number plate "PLAYER" ?
What a complete wanker.
Those plates were on a red s14 about 7 years ago and it's been on a Porsche boxter and I think now a Ferrari.
So .... In seven years he/she has gone from a S14, to a Porsche to a Ferrari. .... Not bad!!
Edited by THE34T
bought the Porsche after crashing the Ferrari.
I used to go to school with the guys son and we work together now.
That car has the stiffest suspension
Saw "BNR-33T" (nsw plate) on some kind of softroader. (pathfinder maybe???)
^^^I put this in the Plates that make you LOL thread.^^^
Coincidence ???
Flamin' Mongrels takin' all the good plates. NO FAIR !!!
Sinista's Plate is pretty damn fine as far as cool plates go.
Got a photo of BNR 34T today on my way back from Sydney haha what a coincidence
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
