Clutch is back – looks brand new. Clamping force has gone from~2400 to 3900. Should be now up to the task of anything this new motor can produce.
Some more parts have started to arrive – Samco hoses for the intercooler pipes and new ducting for the front brake cooling ducts from the front bar.
New rear diffuser brackets. I will get photos of before and after for installation.
The ducting is a standard SAMCO product. Williams Race Services is the aussie dealer ('Mike' helped me out with my stuff):
http://williamsraceservices.com.au/shop/index.php
SAMCO specific site with prices:
http://samcosport.com.au/index.php/race-parts/brake-duct.html
Wind-up of clamp load and resurfing of the puks & flywheel. Everything was in pretty good order.
Sweet! Unlike mine that went up for a rebuild and came back totally replaced :laugh:
Have you got pics of the plates etc? Just out of interest :)
Coatings done – Sickkkkkkk!!!!
Hot side should be installed on the motor today or tomorrow.
I also recently invested in some 2200cc EV14 injectors (thanks DVS-JEZ for the awesome price) with the intention of eventually converting the car to flex-fuel. I was in Perth last week and found that it is currently illegal for the servo’s to sell E85 from the bowser. So E85 plans have been put on hold.
It didn’t really surprise me that much that they didn’t have bowser E85 TBH - they only got shell v-power a year or two back. The WA (or Wait Awhile) government always seems to be a few years behind picking things up from the rest of Australia.
  • Like 1
Holy sheeeeeeeeeeeeeeeeeeeeeeeeeeeeeet! Looks smick :woot: AND its black :ph34r:
Damn WA, just stay in Newy and Cruise ;)
You can't have the monopoly on the black themed engine bay!!!
Yeah dam WA :domokun: . Two years i had the car in newe, met one other current skyline driver before i took it off the road, and now look at the crowd thats here.
I'll be back eventually :-)
Edited by wedge_r34gtr
Hot side on.
Gearbox has also been picked up so everything is ready to go in. Should be installed and running by end of next week, just in time for shipping to Perth.
Piggaz - Paul didn’t do that intake mod you sent through due to time restraints. Next time i add some mods that require a new tune, i'll do it then.
Cheers,
Joel
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
