So something that I've recently been questioning is why many results of the 7's in "RB26 turbo upgrade, all dyno results" thread are the way they are.
I'm lead to believe that these are the most responsive turbos of the bunch when comparing against the -9, -5 and -10. Quite certain that most people who
have these turbos are reaching full boost quite a bit earlier than 4,000rpm; if anything, probably closer to the 3,500rpm mark?
Which makes me wonder, why are the below dyno sheets showing full boost at such high rpm? Some are as late as the 5,000rpm mark, wtf?
I understand that dyno graphs and real world may differ, is that what's responsible for my misinterpretation?
Would be great if the owners of the cars below could have a say in this as they would most likely know whether or not the dyno graph is a reflection of the real
world boost curve. Anybody with a similar setup is also most welcome to provide some feedback.
300wKw at 20psi on 98RON
R34 GT-R V-Spec II
* -7 Turbos
* 700cc Denso Inj
* Power FC D-Jetro
* Blitz front pipe
* K & N Panel filter
* Greddy DSBC
* Tomei Poncams 260/10.25
* Tomei Cam Gears
* Bosch 044 fuel pump
* Nismo 3" Exhaust
* Hi Flo Cat
Unopened RB26DETT
Stock cams
HKS Cam gears (inlet at 0 Exhaust retarded 2 degrees)
-7 turbos
TOMEI s/s dump pipes
3.5" do luck exhaust
Trust 100mm fmic
walbro fuel pump
stock fuel reg
Sard 700cc injectors
Power-FC D'jetro
398.3hp at all 4 hubs @ 1.2bar
99 R34 GTR non-vspec
Unopened engine. Done approx 70K.
100K service done with all OEM parts, including water pump, timing belt, bearings and seals.
Adjust Cam gears
Garrett -7s
Stock injector
Stock fuel pump
Stock air box with high flow air filter
Stock intercooler with full HKS hard piping
Nismo fuel regulator
Spitfire Coilpacks
Iridium spark plugs
EVC 5 boost control
Power FC
Stock dumps and manifolds
Full NISMO WELDINA NE-1 Exhaust De-Cat
Koyo Radiator
EXEDY hyper multi twin plate clutch
Tuned @ Racepace
Pulled 288.7 RWKW @ 18.2 psi, on BP 98.
Bought Sard 700cc and Bosch 044, but told no need to install them as I had -7 only. Stock injectors cycle duty @ 98.8%. Knocking rarely exceeds 25 under the sun. Feels hell a lot better to drive.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=322462
Updated in BOLD
1995 R33 GTR
Performance list:
garrett 2860 -7 running 20psi drops to 19psi
tomei dump pipes
trust front pipe
ballistic cat
nismo catback
1000cc injectors
splitfire coilpacks
bosch 044 fuel pump
haltech platinum pro (mafless tune)
bp ultimate 98
115 Greddy front mount intercooler and piping kit
Greddy air intake kit
280awkw at 19psi
Now 310awkw
There are many factors that will influence what your talking about
-health of engine
-how the dyno is set up
- restrictions in exhaust
- aggressiveness of the tune
These are to name just a few
my old gtr had -7's with all the fruit made about 300rwkw and the dyno sheet shows it making full boost at 4800rpm, on the street it definetly feels much sooner then that !
GTR_JOEY:
I agree on all accounts, however the specific graphs I've chosen mainly consist of quite well known workshops which have (I assume - probably shouldn't) relatively honestly setup dyno's. Correction factor will take into account ambient temp and altitude? These setups seemed to have relatively decent exhausts.
SiR_RB:
How much sooner are we talking? 4,000rpm? Below 4,000rpm? Have you ever loaded it up in 4th gear and had a look? I'm quite happy with the idea of 300kw-330kw.
My friend's r34 gtr was already quite quick at 318rwkw tuned by racepace. Mine being 5 speed 4.11FD in an R33 GTR may not feel quite the same, but I'm hoping some weight reduction and mild increase in displacement (86.5mm built motor) would negate the difference of the 6 speed
-health of engine
Exactly. I was driving a mates GTR with -7s not 7 days ago.
I can tell you now by 3300rpm it was well and truly game on where my -5s were ~4000-4200rpm. -9s are about 3400-3500rpm.
Yet when you dyno the cars, the graphs come on & look very similar (nowhere near 800rpm), due to ramp rates and other factors.
Why is it that they have set the ramp rates to make full boost look like its coming on later than it is?
You say that they are well and truly on by around 3300rpm. I take that as the perfect world situation on
a stock motor with all the correct supporting parts.
In the event that you run these turbos with a mild built motor for example with:
86.5mm cp 9.0:1
Light h beams
0.9-1.1mm Thin metal head gasket to keep comp high
Light head work to clean ports and improve entry and exit velocity
A GOOD TUNE
would it be reasonable enough to say that these turbos are likely
to come on even earlier, say around the 3000rpm mark?
-7s coming on by around 3000rpm mark (probably e85 or well sort out
motor) making power to 8000rpm would really be something impressive
I think. Sure it might be short of 350kw atw but a solid powerband of 5000rpm
is not something to be laughed at
-7s will nose over well before 8000 rpm
At the end of the day -7s aren't going to flow much more then 300rwkw and these days that isn't alot of power anyway
Would still be a reasonably quick street car no denying that..
I would find it boring though
86.5mm cp 9.0:1
Light h beams
A GOOD TUNE
When I say "on", you aren't making "full boost" - given such a term is silly. Is "full boost" 5psi or 50?
By 3300rpm the torque is coming on and boost is really driving so at a stab maybe 10psi which is 10psi more than a set of -5s would at the same RPM.
Every setup varies but i think 3000rpm for them to be really moving is a bit of an impossibility.
Despite small increase in displacement, e85 and some headwork?
I understand that stands true for an unopened motor on with 98 but with the above changes?
Edited by RB2600
Fair enough, I was having a look at the build of the old Advan R32 GTR and have just accepted that I won't get it to that type of response.
According to Russ, 3500rpm and the power was already over 300kw with a peak of 380kw-400kw depending on temps. Although it quite an extensive build,
I still wonder..really?
Starting to lean towards the -9 if they're only 100-200rpm behind..
You would need to spend big cash to get that sorta power and response
Ie
Big compression
Stroker
E85
380-400rwkw on -7s is pretty out there
Edited by GTR_JOEY
hi Roy
i will try and tell you what we have found really important and our mods.
power is approx 380 to 400 kw's @all four depending on weather and temp.
so yep, still 2.6 bore size, 270 cams tomei, adj cam gears, cleaned up cylinder head ports, n1 valve springs,cp pistons, tomei rods, n1 oil pump with reinmax gears(also use tomei oil pump previously), hi octane racing large sump (will be going to a hi octane racing 4 stage dry sump in a month or so) standard exhaust and intake manifolds, are intercooler, n1 garret equivelant turbo's, greddy intake boost pipes, apexi airfilters, autronic ecu and cdi ignition,gonzo exhaust, vp109 fuel( good for 30kw's and much safer than pump fuel), tilton brake pedal box, australian spec tein suspension, bosch fuel pumps, advan suge tank, npc clutch ( i swear by it!!), carbon tailshaft. block and crankshaft are standard, acl race bearings, 25 row oil cooler, standard blow off valves. we also run a water sprayer for the radiator and oil cooler for longer circuit runs.
we have tried hard to make the power come on hard down low in the rev range , which makes it easier to drive, we tried aftermarket extractors and the car made more power but we lost over 500 rpm before boost would come on so we went back to standard manifolds, adjust cams to get power as early as possible, car has over 300 kw's at 3500 all the way to rev cut, rev cut we have lowered to 7800 till we get a dry sump.
the other thing we have spent a lot of time on is the 4wd system and wheel alignment setup, nearly all r32 gtr 4wd drive systems we have looked at including our car when we got it, do not function as they should. wheel alignments also have been a real issue. we have had a lot of trouble get alinment shops to align to the spec you ask for and ahen checked they are way out!! we now do all our wheel alignments by string line and have had far better results.
the car will be coming off the road in two months(after nsw dutton and maryborough sprints) for a full rebuild, dry sump if not before) , side exit exhuast for events that allow it, chromoly strut to strut cage, try to lighten it some, total repaint, stack dash , hopefully carbon doors, bigger swaybars & a few other changes.
hope this helps if you want to anything specific just ask
cheers russ
Not a stroker, but a damn good motor lol
HAS he ruled out a stroker??
Not trying to argue with you but he just says "standard bore size" which obviously leaves the door open for a longer stroke size??
It's pretty amazing power if it is all standard but seems to be pretty solid power with fairly standard upgrades and -7's.
I was assuming it was not stroked considering he mentions "standard bore size, standard crank" but now that I look at it, he does mention Tomei rods, so they're possibly the 119.5mm centre to centre model?
Which would effectively increase stroke to 77.7mm?
Bleh...slightly off topic, but I found a lovely crack in the block...guess I won't be thinking about turbos anytime soon...
the crack is actually worse than it looks in this photo :(
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
