I didnt do it myself but the guy who i bought it off. Everything seems fine with the engine, but the car is running way too rich...so much smoke and smell.The engine is running low compression pistons since its was originally a rb20det. What can i do? put non turbo injectors and/or change the fuel pump?
  • Replies 46
Injectors etc probably arent going to help, more likely an ECU will...... But i must ask WHY did he remove the turbo? The RB20DET - T would be terrible to drive? (No offense)
crap power low end but it picks up like a skyline should after like 5500rpm. BTW i think there is already an ecu..u cant just take the turbo off and expect your car to run...it wont!
Oh it'll run just fine.
Might be a lil' rich though.
an NA that piks up after 5500. Far out. your on p's by the sound of it?
the only money id spend on that is to get a rb25de and bolt in.
you think there is an ECU? is this car on bricks?
go fist yourself, i want to drive a non turbo r32, f**k me right? i dont care ive been looking for a factory gts for a while now and most of them are either auto or are really expensive. They are rare...more and more r32's are off the street nowadays. The car drives fine, it just runs rich.
You said its got a non turbo computer? What colour are the injectors? pink or red?
Also a rooted o2 sensor will cause this.
injectors are greyish black
here's a picture of the ecu...it looks aftermarket : http://imgur.com/2UWCH
Looks like the NISTUNE logo and Envy Dyno.......
ye i told you it had an different computer
id also like to mention im still using the factory turbo manifold...its been modified to go straight to the dump pipe. Maybe its a bit restrictive? getting different headers will be one of the first mods id do.
haha, hit a sore point did i mate?
Sorry, your car is not rare. But... What you could do.Is grab a NA rb25de for Say $500, Bolt it in. Not only will you have a stock DE motor, But will be able to enjoy the extra .5 Lt. Win win is it not?
Otherwise you could spend money on what you currently have....And still be drving around in a low comp 2L NA
Edited by sydking
and pay thousands to get it engineered? no thanks bro
Edited by IM-32-FK
Definetly buy a rb25de motor, cheap as compared to fixing yours to run properly as will only take a day to fit of you have some knowledge. Also will go way quicker than what's in there now
Hmmm, you should watch what you are talking about. As for his suggestion of putting a proper non turbo motor in there is the smartest decision you will ever make.
As for why your car is running shit? Its because the turbo is missing doofus. And want to know another thing? Your non turbo'd car is still illegal for you to drive on your p's because it was registered as a turbo.
So instead of spitting in people's faces like a spoilt brat, just take what he says and reply in a manner as follows, no thank you, I would rather try something else
lol u driving a non turbo 4 wheel drive r33 ROFL what a joke why bother having 4 wheel drive when your car dont even have power lolololololol
Doesn't need to be engineered as its a factory motor designed for that chassis. Also awd helps heaps in wet, I know my rwd r33 has stepped a few times when you don't want it to.
Also, what's with the attitude, why bother asking for help of your not going to take it positively
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 🤣
    • Perfect! Thanks for this, both look like great options!
