Noise restrictions apply.
Must have CAMS L2S and CAMS Affiliated club membership (SAU VIC).
The scrutineering here is a little tighter than elsewhere. So make sure your fire ext are BOLTED in and are within the 3 YEAR
date cycle.
Standard double latch bonnets are fine.
Normal helmet and clothing rules apply.
http://www.maserati.org.au/download/pdf-files/Sand-141012-Supp-regs-Entry-CAMS-OK.pdf
https://www.sau.com.au/forums/topic/409808-14th-oct-maserati/
  • Replies 79
It runs pretty much the same.
- They run a split roast for lunch
- Stop for lunch
- 4 colour groups
- White, Red, Yellow and Green
- Generally Red or Yellow will get split into A and B (two different groups), so 5 total.
- Maserati club members generally have older cars, thus by the end of the day they are either fat on lunch and don't go out or their car is busted
- Not that many exotic turn up actually, more ex tarmac rally cars and the like. You do get the odd lambo and feza turn up
The sound restrictions do suck, the track was there before the house yada. But that is what we have to deal with, so if you have ext gate you are f*ked. Plain and simple (there are exceptions, but you have to do a lot of work to the exhaust to quieten it down)
I've never triggered it at Sandown so it's not as bad as you would think
it just dosent make sense to me why they would put it at that level.
if they put it at 90 or 95 whatever the Vic EPA legel limit is, then that makes sense
EPA is right at the exhaust, this is from 30 meters, across the track and over a wall...there is a big difference.
what he says
mine is no-where near road legal, but never triggered Sandowns noise restrictions.
M
ive had a major epa done before on my old skyline, emissions were measured at the exhaust, noise from a distance
anyways im more just having a windge about the fact its a race track and you cant go make noise :/
street epa is measured at 1 meter..30 makes a huge diff.
that said according to PI I am borderline as it is....so winton wins again
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
