  • Replies 100
Now come on Josh, if you stacked your car you might not want to be named and shamed. Glad that the few midnight purple 33 GTR's I know are safe and sound.
Feel bad for the owner and despite all of our speculation we don't know the particulars of the incident. So let's not go all "A Current Affair" on this poor soul. No doubt he's mourning his loss.
My curiosity has me coming back into this thread too, but I do think everyone is entitled to some privacy if they want it.
Tis true.
I'm just a gossipslart.
And this is the only exciting thing going on in my life right now.
My bad.
Tis true.
My bad.
I'm just curious because it happened just down the road from my place (If I'd gone out 5 minutes earlier to my mums I'd have actually seen it happen), and I saw the aftermath. The picture posted really doesn't do justice how badly bent that car was.
It is possible that its Gtr-400 from Robertson, but he's about 50 years old, and doesn't let anyone drive it, he might drive it once a month
Like I said, I'd know of a GTR in Robertson.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
