Hi Guys,
I am looking to get a Skyline gts that has been defected before for noise, height and wheels...Car has passed the compliance since...it looks very attractive as well, which may attract cops attention with the nice looking wheels and i think it has a black carbon fiber front bonet...
It has a high mount turbo and i have a history of my GTR being Defected before with mods...
Just want to know if I am looking for more trouble and getting into more shit? I am afraid that the high mount turbo might be a problem if i get pulled over...car is doing 300kw atw and its a cheap buy of 10k with forged internals...
Anyone with any suggestions?
  • Replies 47
Sometimes cheap is a bad thing as it could indicate faults.... I would be speaking to a Rego guy to make sure it'll pass before thinking any further, and as Mr NPC said speak to a relevant engineer :)
The car is very tempting to buy with the mods listed on it...
I am only worried about the high mount turbo...
If the cops do a random rego check and the car has a defect history, im sure they will pull me over and defect the car again...
Change to low mount and get retuned. There's a pretty good fabricator in SE That will make it fit
Depends what turbo it is, cops are probably going to notice a big ass intake pipe even if it's low mounted etc..... Having a defect history makes it a target....
A different car and different owner. Seriously if you think it's linked specifically to the plates then get new plates! Simple. Don't drive like a dick and you won't get pulled over. My cars bright orange and its fine. Popo compliment it
Has not lived in Knox^
Sigh, not this shit again.
It's a skyline
They will pull you over irrespective of your defect history. They will only know that after they've already pull you over so i don' see how thats a factor of consideration.
Very different views...
Well, lets see how we go....
I got defected once coming back from KNOX!!!! i hate to go there again in my skyline after that :)
Well, i got a few other cars in mind and will be putting the car on mrs name :P, just to be safe...
Yeh neither does lav..
What not this again. Do u get pulled over a lot?
See this
Everytime someone starts a thread on defects, there is the inevitable "don't drive like a dickead and you have nothing to worry about" comment. Usually comes from someone who has never been defected and is as dumb as saying racism doesn't exist because they've never experienced it for themselves.
I got defected while driving completely normal. Cop said he saw me from the other side of the road and did a u-turn because my car looked low. It really just depends on the cop you drive past.
Obviously, if you drive like an idiot then your chances of attracting attention are greater.
All i see is the same view?
Fix it, or prepared to get reamed.
Don't worry about the NSW commenters, unfortunately they don't understand Victorian law, VASS or EPA - so ignore those comments about engineers and similar.
Also true.
See this
I've been defected for rear tires. Cop said "good to see you weren't driving like a dick" and told me to replace and go v roads.. No fine, no roady.. Maybe I just got a nice copper
Yeah, i was driving behind a mate who was completely drunk but still decided to drive...I was doing him a favor to make sure he get home fine and i had my Mrs with me in the car and i was driving like a gentleman and at least 2 cars behind my mate and the most left hand side of the road while many other cars over-taking me...
The cops pull me over saying that my car looks low...put the roller under the car and i saw it went all the way through but they said its touching the exhaust, then told me to open the bonnet and there we go, pod filters...DEFECT yellow note was put on the windscreen...
Then i got off from skylines but still missed my GTR and now I want to get back into it and find a standard looking car with mods...I remember reading a post here a while ago someone said that there is a dickhead pig on stud rd that always pull over the Japanese cars...
Hmmm...true as well R31Nismoid :)
Will probably get it re engineered...
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
