Currently my R33 GTST is at the tuners again. They having trouble getting decent power out of the car. Curious to hear peoples thoughts.
Current modifications are;
Rebuilt motor & reco head 10,000kms ago
GTX3076R bolt on turbo, FMIC, intake.
Wolf 3D v4.
Full exhaust
044 fuel pump & nismo 740cc injectors
At 9 psi of boost it makes 190rwkw
At 16psi of boost its currently making 220rwkw and starts to detonate so they must modify the timing they said.
I thought it would be alot higher than this for that boost level?
Thanks.
Edited by GotsWapan
https://www.sau.com.au/forums/topic/410142-low-power-for-mods/
what does full exhaust mean? those symptoms are bit like the exhaust is blocked, like a cat or a restrictor..
I think the 9psi to get 190kw is probably right, with 15psi i was getting 260kw so you should be around that..
what housing is it?
Now you mentioned that it reminded me of this -
http://www.skylinesaustralia.com/forums/topic/403526-rb25-gt3076r-turbine-housing-size/
Sounds like a similar thing.
Certainly sounds like just another case of butchered housings. If a GT series have issues with them, it's only going to be worse with a GTX given they are meant to make more power.
If it's not the housing
- Exhaust
- Timing belt is out a tooth possibly
Wolf 3D v4.
Full exhaust
Thanks.
Hey mate, have you got the detonation verified with headphones or is your tuner just running of the knock sensor?
Reason being, I used to get alot of noise which the knock sensor interpreted as detonation.
I'm also running a GTX3076r on my RB25 and make jsut a tad over 300rwkw on 21psi, so would expect yours to be around the 260rwkw mark like SIlverS2 said :)
Well if you runit on stock manifold as a bolt on turbo internally gated on that housing its not going to make lots of power. GTX3076 is ideal for external gate. Also I didn't see metail induction pipe in your mod list, you will need a 4inch metal induction pipe for that turbo.
Not sure of that turbodragon, I assume its with headhpones. Its a fairly reputable workshop and they do alot of RB25 work and work on VLs. I havent spoken with them today. Will ring them soon
Best to ask them and find out. Could save you a lotta time and cash if it was just phantom noises coming from the harmonic balancer or soemthing lol
Plenty run a 3" that just steps out to 4" @ the comp housing to get a hose around. In fact that's how most are done come to think of it given a Z32 isn't 4"
Yep, Z32s are only 3" so 3" intake pipe and a 3"-4" reducer at the comp housing inlet.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
