Okay first up I previously had a built 25/30 running 356kw using the same head and custom intake manifold.
Only changes this build were to the oiling system, 0.5 higher comp ratio, total seal rings, cam change from 232 duration 6.5mm lift cams to 262/9.1mm with appropriate springs and port tidy up and match the intake manifold ports.
Now I had discussed with the tuner I only wanted it ran off spring pressure in the wastegate so I can learn to drive it at that power level First, made it very clear I wanted a super safe tune and wasn't to concerened with the power level.
So he apparently he had it up and running, bedded the rings In on the dyno for around 10kays, changed out the mineral oil to redline oil ready to get into tunning.
Then he tells me he's ran it up for a power run without touching anything with the tune or boost, where it pulled only 320wkw on 21psi. Down considerably on the old setup and boosted well past where I wanted.
Now apparently Afr's were safe the whole time.
After fixing a small coolant leak the car wasn't idling right and had smoke pluming out of the catch can. Comp test revealed front 2 cylinders down around 50psi and the rest were at about 110psi (which I feel is extremely low for a brand new engine).
Now the engine builder and tuner are unsure of why this has happened but only suspects are the custom intake manifold which kinda points the throttle body towards cylinders 1-2.
I would post a pic of intake manifold but I'm posting from iPhone away at work.
But it's the intake manifold off dahtone racings old 2GUUp candy red r32 skyline.
Now I'm curious if anyone has had similar issues due to a plenum? And who should kind of be at fault here?
I'm far from happy so far!
Specs of the build as follows: rb25/30
Custom je pistons with total seal rings and spool rods, usual block and crank prep, nitto oil pump, lewis engines race sump, r32 rb25de non vct head, ported, springs, cam tech 264/9mm cams, custom intake manifold, sard 700cc injectors, twin entry rail, walbro lift pump, 044 feed pump, haltech e11v2 ecu with boost control. Twin scroll t04z, 0.8 rear housing, turbo smart 50mm gate.
Sorry about big post! Cheers all
  • Replies 68
https://m.facebook.com/dahtoneracing?refid=9#!/photo.php?fbid=1174491395851&id=1035030725&set=a.1174487315749.26782.1035030725&__user=553976899
I can't post a direct pic from iPhone sorry. Here is a link tho.
I have that entire top end, head plenum injectors rail throttle body.
Mate This will be a story with no happy ending. Workshops are very forward stating if the motor pops on the dyno they not at fault. If they monitored the runs right they could show you that the AFRs where safe but i suspect they wont.
I'm away at work at the moment which makes this whole situation shit, I'm back on Monday morning and going straight to the tuners to demand to see the dyno read outs
You'll get a MUCH better result if you go there and ask nicely to see them. Don't assume they are at fault, it will only make things much harder for you.
Instead, go there with your objective thinking cap on and listen to what they say, take all the information on board and then ask some other experts about what has been said. Try to take someone with you who might know a lot more about these things.
Think about trying to find out WHY rather than WHO and the WHO will work itself out in the end.
Okay I worded that very Wrong saying demand.
I entirely understand the power of respect and level headedness in a situation like this, i know the finger cannot be pointed at anyone just yet untill we figure out what caused this failure.
Last I spoke with tuner and engine builder they were pulling off the intake manifold to have it put on a flow bench.
But if the needle does land on this intake manifold after flow bench testing and the engine builder had to weld up a small tab on the intake manifold and checked the port matching on the manifold, said it looked like a good unit.
shouldn't perhaps some concern have been expressed if it didn't look up to the task?
Forget looking at the cause until you have fully accessed the outcome. Get it apart and with careful inspection you will be able to pin point what and how this has happened . The dyno runs showing afr means little as it shows an average tailpipe mixture not individual cylinder mixture and shows nothing regarding detonation, which if it's drilled something would be the cause wether a lean mixture concentration promoted the detonation in the first instance.
Zachary.
Pull the engine down and assess the damage. Only then can you begin to unwrap the puzzle pieces in reverse
Thats a great way to put it!
And sorry to hear about your engine, that must really suck :(
Edited by JustinP
They informed me they put a borescope down the low comp cylinders and they had signs of Det and damaged bores on my already 87mm bored block.
I have heavily researched hard running in methods etc.
Now the tuners run in method was
Fire engine, free rev and blipping throttle under 50% till at temp, shut off engine check leaks etc, let it cool down, load it on the dyno and sit it at about 90kmh in 4th gear under medium load lowish boost for the 10kays.
I was under the impresion a good ring bed in required vartied loads, revs and engine braking?
On a fresh as fresh engine with good ring bed in what kind of cylinder pressures should be expected?
110psi for cylinders 3-6 seems low to me.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
