  • Replies 56
Yeh man.
Your cars quick!
And loud!
Looks very nice aswell.
:D
Thanks man. Your car sounds pretty good for an internally gated turbo! :P I noticed what you were talking about with the popping on decel by the way, that's normal. You may have noticed mine doing it as well. I enjoyed the flames that yours spits though! :laugh:
I also found out you know my brothers girlfriend lol.
Small world.
:mellow:
Who's that??
Carrisa?
( well she said she knows you? lol )
Normal popping is good for me :)
And yeh i loved that i do flames!!
Got me all tingly knowing it does that.
Still havnt listened to a outside noise of my car though, will have to go through all my gopro stuff and other videos i took.
I entered the Off Streen drags at the end btw......My first race...against a r35.......i was like GOD DAM IT!!!
He was about 3-4 car lengths infront of me at the end, they launch fast :(
I didn't see you out at the drags although there were a few cars out there! I got taken down by that red caged evo. Turns out stance spec suspension, high air pressure, stretched tyres and a decent launch ends in first gear going fkn nowhere - lol!
Carrisa?
Carissa King? Really? Wow haha. Is your brother Jake?
Yeh I didn't do the drags this year, did them last year and fkn sitting on the track for an hour before getting your little 7-8 second run is just fkn crap. Couldn't be bothered this year. Last year I raced two bloody 9-second V8 drag cars lol, the second one beat me by 2 car lengths doing a powerskid the whole way :glare: If you ever get to see the Powercruise DVD from last year, both my runs are on there.
Haha dude i saw that. I was thinking how unfair is it for them to pair you up with an R35 GTR..
the little rx5 that was infront of me....didnt go with the r35 like he was supposed to...he just stopped before it and made me pass him :(
The blue R100?
That think is crazy! 300rwhp in <1,000kg :O
Was good to see and meet a few of you lads, Unfortunately i had a few small issues with the Gtr this year..
Was absolutely devo, waited all day to run those off streets and on the last cruise session popped a fuel pump fuse with a dead short somewhere between the battery and the relays in the boot.. and 10 mins wasnt enough time to fix!! But a quick fix allowed me to drive it home, was sh*tting bricks driving past the cop hiding in the bushes on yanchep road with the slicks on though!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
