No, don't T into that hose, as said you won't get vacuum.
On the back drivers side of the intake manifold there will be a vacuum line the same size as that one which goes to your standard boost gauge, T into that.
Basically you can hook your boost gauge up to anything that's plumbed in AFTER the throttle body, except the fuel reg hose, but that's at the front of the engine anyway.
Why cant you t into the fuel reg hose at the front. thats where mine is.
It'll work but if you ever get a leak for whatever reason it'll affect fuel pressure and therefore fuel ratios. Best to leave something so crucial alone and use one of the many other points available, the standard boost gauge nipple is in the perfect spot and is the perfect size too, why wouldn't you use it?
Ah crap time to re route some hoses.
Do the S2 R33s Have a rubber cap on the front intake manifold nipple from factory?
ok, so im 99% sure this is right now lol.
I take the line i've outlined in red out of the sensor (circled in blue). Hook the T up to that, another tube back to the sensor and then the vac line from the gauge to the other end of the T.
Correct me if i'm wrong.
I dont blame this guy lol, i knew almost nothing about the engine lay out also, and the information given here was helpful but i was a bit reluctant to T into the BOV line.
My boost gauge is still sitting in my glove box, haven't had the balls to cut anything and connect it yet either.
But just to confirm, is whats said in this post and the photo above correct? if i follow this, would the boost gauge work with no troubles from the car 100%?
so, i bought a cheapo gauge from ebay last week.
http://www.ebay.com.au/itm/400336875504?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
how would i be able to tell if it's going to be more accurate than the stock gauge or not? Also has the same style mount you just linked Johnny :)
Speaking of good gauges and accuracy. Does anyone know what the quality of TurboTech's boost gauges are like?
I recently ordered a boost controller from TurboTech (after reading how awesome they were) and it came with a mechanical boost gauge.
Haven't hooked it up yet tho, wanted to know if it's even worth installing first.
Now I assume that they are not their own TurboTech branded boost gauges, that they merely on-sell another brands product packaged in with their own.
I also assume that with all the raving reviews of TurboTech's controllers they wouldn't go jeopardising their great reputation by supplying sub-par accessories; but hey, I might be wrong...
I'm going to assume they're pretty accurate Brad. Like you said, they wouldn't jeopardise their product with something that won't show an accurate (or more accurate than stock) reading.
This might be a very stupid question, but I'm going to ask anyway lol.
I've read around that people test the accuracy of their gauge by using an air compressor.
I don't have an air compressor, but would I be able to use one of those free air hoses at petrol stations to test my gauge?
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
