No, don't T into that hose, as said you won't get vacuum.
On the back drivers side of the intake manifold there will be a vacuum line the same size as that one which goes to your standard boost gauge, T into that.
Basically you can hook your boost gauge up to anything that's plumbed in AFTER the throttle body, except the fuel reg hose, but that's at the front of the engine anyway.
Why cant you t into the fuel reg hose at the front. thats where mine is.
It'll work but if you ever get a leak for whatever reason it'll affect fuel pressure and therefore fuel ratios. Best to leave something so crucial alone and use one of the many other points available, the standard boost gauge nipple is in the perfect spot and is the perfect size too, why wouldn't you use it?
Ah crap time to re route some hoses.
Do the S2 R33s Have a rubber cap on the front intake manifold nipple from factory?
ok, so im 99% sure this is right now lol.
I take the line i've outlined in red out of the sensor (circled in blue). Hook the T up to that, another tube back to the sensor and then the vac line from the gauge to the other end of the T.
Correct me if i'm wrong.
I dont blame this guy lol, i knew almost nothing about the engine lay out also, and the information given here was helpful but i was a bit reluctant to T into the BOV line.
My boost gauge is still sitting in my glove box, haven't had the balls to cut anything and connect it yet either.
But just to confirm, is whats said in this post and the photo above correct? if i follow this, would the boost gauge work with no troubles from the car 100%?
so, i bought a cheapo gauge from ebay last week.
http://www.ebay.com.au/itm/400336875504?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
how would i be able to tell if it's going to be more accurate than the stock gauge or not? Also has the same style mount you just linked Johnny :)
Speaking of good gauges and accuracy. Does anyone know what the quality of TurboTech's boost gauges are like?
I recently ordered a boost controller from TurboTech (after reading how awesome they were) and it came with a mechanical boost gauge.
Haven't hooked it up yet tho, wanted to know if it's even worth installing first.
Now I assume that they are not their own TurboTech branded boost gauges, that they merely on-sell another brands product packaged in with their own.
I also assume that with all the raving reviews of TurboTech's controllers they wouldn't go jeopardising their great reputation by supplying sub-par accessories; but hey, I might be wrong...
I'm going to assume they're pretty accurate Brad. Like you said, they wouldn't jeopardise their product with something that won't show an accurate (or more accurate than stock) reading.
This might be a very stupid question, but I'm going to ask anyway lol.
I've read around that people test the accuracy of their gauge by using an air compressor.
I don't have an air compressor, but would I be able to use one of those free air hoses at petrol stations to test my gauge?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
