skyline mods!!
Tein Coilovers all round
ACL forged gasket and ring sets
Forged Pistons .5 Oversized
GTR Crankshaft
Plenum and top feed fuel rail,
ID 1000cc injector dynamics fuel injectors 5ltr surge tank, and full Kevlar fuel lines, to run(e85) fuel
Twin o44 Bosch fuel pumps,
Veilside Exhaust System
Greedy electronic turbo boost controller
HKS Super Sequential BOV
HKS Front Mount intercooler
HKS 3037s garret turbo,
Apexi Power FC Computer and Controller
All Custom Intake Piping
Turbosmart FPR 3000
Turbosmart Boost guage
Turbo Timer
Custom Oil Catch Can
K&N Pod Filter 4in
New Battery
3 Stage Alarm System
Heavy Duty Clutch
Alpine Head unit
Twin JBL 12in subs in box
At yesterday's SAU.NSW Tech Arvo hosted by Theo - CEO of SYRIOPS Engineers
Thanks to Moelders.
Thanks to JEM who prepped this car.
Defect station looked this over on Friday.
I believe the engineer and coppers admired it.
  • Like 1
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
