  • Replies 262
I'll be heading up a bit later in the afternoon in the 33 for dinner, then I'll likely come home and drive up again tomorrow in the van. Bringing change of clothes in case I sleep in a gutter somewhere instead of coming home though.
Was good to meet all the Canberra guys I hadn't met before!
Missed me :P the only other ACT car to be on the track, whats your excuse :P
Mine was I spent the majority of the time trying to fix my car. Installing new rear brake pads and later a broken water pump, my day was over :(
You did well Daniel. Good launches and gear changes :thumbsup:
Good to see enthusiasim to track and strip the Skyline.
A really good day but got a lil sunburnt spectatin
Thanks heaps mate!
Managed a 14.3 @197kmh
Pretty happy with it being my first time ever and with some normal street 595's
Also found why it over heated as well
Manged to shred my fan belt haha
Spent 2 hours on the side of the road replacing it
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
