Driving home tonight, the tacho, speedo, odo & everything in my instrument cluster went limp & died in my M35
They're all still lit up like they're supposed to (with the exception of the backlit odo & gear selection indicator) - the gauges have all just stopped functioning.
I've checked the fuses & can't see anything blown. Anyone got another suggestion?
:unsure:
https://www.sau.com.au/forums/topic/410714-instruments-dead-wtf/
Battery healthy? Able to check by chucking another one in?
I remember someone had an issue with the dash- car does funny things with a failing battery.
Other things could be can bus ground wiring or something equally wierd.
Pretty common apparently - happened to me a few times - initially just disconnected and reconnected the battery and they went ok for a while and then did it again and now they are fine. You could try taking the cluster out and waving a heat gun over the back of the board or get a small soldering iron and touch any dodgy looking ( I think "dry" is the term but I'm no sparky) joints.
I might try removing it & brightening up the plug connectors on Saturday & see what happens.
I'm just concerned its a computer problem of some description that won't ne resolved without burning the car to the ground...
Its not a computer problem its just a bad connection.
Turned out it was a blown fuse in the kick panel which had shut the alternator down.
Anyone got an English diagram of that fuse panel btw?
http://www.skylinesaustralia.com/forums/topic/309837-m35-fuse-box/page__p__5108325#entry5108325
Why did the fuse blow? Fuses don't blow for no reason. Now the fun begins!
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
