trans was opened up today
had a proper oil flush/replace 10,000km ago.... currently the fluid looks like red glitter paint. there is absolutely nothing left of the friction bands. And before you say it, NO i dont do burnouts. This is after normal use (by me). maybe the previous owners were not so kind...
so its in for a complete rebuild plus trans kit. $3000 approx..... and the shift kit is the cheapest bit.
this probably explains why my gearchanges have felt so slow and lethargic. unfortunately it gave no other warning signs, crunches or bangs, it just stopped working.
Not stressed about it. Love the car to bits
Edited by Deep Dish V35
factory spec bands, solenoids, etc. just the modified valve body. theyve been recommended as a bit of a nissan specialist who do in-house component mods.
the positive is, its just $1000 more than a replacement USED gearbox.... which i see as the better option
another note: have researched the re4r01b gearboxes, turns out the ones fitted to the VQ motor has different input/output shafts to the RB version, plus the bellhousing..... so you cant assume that all those gearboxes will fit
heres the diagnosis...
upon disassembly, the guys found that the first clutch drum had failed. the friction plates should be retained by a large circlip - that clip had popped out, allowing the friction plates to travel past their correct location and eventually shave themselves down to nothing. this generated extra heat and extra load within the trans. The trans fluid in the pan looked like glitter paint.
The 4 speed auto has only 5 friction plates in there, mine has now been upgraded to the turbo version 7 plate and drum assembly.
the servos have also been discarded and replaced with new larger units from a turbo assembly.
the solenoids have all been replaced for new
the torque converter has been stripped down and rebuilt with all new internals
and lastly, the valve body has had a custom upgrade (not transgo.... apparrently his are better)
all this , including R and R, and a weeks labour.... $3050
The trans guy say this is THE way to upgrade the RE4R01B 4 speed auto box. In my opinion it is too much money to spend on a V35 upgrade unless youve already broken it, however it works out to being only $500ish more than buying and installing a second hand box from a wrecker..... so definitely better for the money.
Will upload a vid to show the improvement next week
under instruction from the trans builder, i am not allowed to use full throttle until after 1000km and a re-check... so here is a short clip of about half throttle from standing start. thanks to my back seat passenger ;)
http://img.photobucket.com/albums/v716/sc850/V35/29A00525-E317-4F2A-9661-AE7C61D1A149-5894-000007E3A7B0C254.mp4
First to second... is quite grabby. Probably too harsh for my liking... we'll see if it eases up after bedding in...
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
