Hmm.... All of it, Lachlan??
I honestly cannot understand how someone can "really not like" daft punk...
You mean their new album? Or just in general
Mainly their new album which I am really disliking at the moment (doesn't help that it's being over-played) but a lot of their older stuff is pretty average IMO.
  • Replies 3.5k
yep not a fan of their new album, like I said in WT, i knew what they were trying to do with it, but I don't listen to Daft Punk for that sort of music and it was mediocre at best.
A lot of their older stuff is hit and miss as well, but I find that with all French electronic music.
Kid Cudi - King Wizard
Bought the new Daft Punk album on Friday; I'm a big DP fan and I have to say it's underwhelming at best. I can see what they were trying to achieve, just don't know if they pulled it off.
