  • Replies 3.5k
Mr Boz delivers once again, awesome set :thumbsup:
Mate, we should catch up some time when your in Melb at a similar like venue above
Glad you like it - I've never been to anywhere that plays non commercial house music or the like. I really like Kerri Chandler though!
It's this very thread that has introduced me to a lot of music from several genres that I never would have heard of otherwise
Edited by bozodos
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
