For sale: set of white NISMO LMGT4s
18x8.5 +30
18x9.5 +35
5x114.3
fronts: 225/40/18 > 90% Adrenalin Potenza RE001
rears: 265/35/18 > 80-90% Hankook Ventus HRII
Price and price conditions: $2,300 neg
Condition: overall very great condition, no cracks, minor rash on two rims (both left side) other than that great wheels
-comes with two plain white centre caps
Pictures: see pictures for fitment on a S15 (sits flush with some negative camber)
http://i213.photobuc...LO/IMAG0415.jpg
http://i213.photobuc...LO/IMAG0414.jpg
http://i213.photobuc...LO/IMAG0413.jpg
http://i213.photobuc...LO/IMAG0412.jpg
http://i213.photobuc...LO/IMAG0418.jpg
http://i213.photobuc...LO/IMAG0421.jpg
http://i213.photobuc...LO/IMAG0416.jpg
http://i213.photobuc...LO/IMG_7877.jpg
Contact Details: Marco
Delivery & Conditions of Delivery: Preferred pickup, can send at buyers expense
https://www.sau.com.au/forums/topic/410905-nismo-lmgt4s/
2,300 ? your dreaming mate
and its tossers like you that have no fkn idea, dude keep your opinions to yourself ya peanut, i spose you have some star corp rims on your car! numbnut
https://www.sau.com.au/forums/topic/410905-nismo-lmgt4s/#findComment-6588371
DO NOT EVER do this ... if you don't intend to buy an item, DO NOT post in a for sale thread.
DO NOT EVER attack the price of an item in this fashion - especially when you are incorrect - as many people have disputed your claim and made you look like a dick.
This is your first and last warning.
https://www.sau.com.au/forums/topic/410905-nismo-lmgt4s/#findComment-6588724
  • 3 weeks later...
  • 3 weeks later...
I wouldn't drop the price any further unless you NEED the cash mate, hold out and someone SMART will come along and grab them for sure!
If they were gloss black I'd be that someone.
https://www.sau.com.au/forums/topic/410905-nismo-lmgt4s/#findComment-6656918
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
