guys, this will be the 3rd one of these events i have held. if you value your pride and joy you need to attend this,
WHERE:
Audio Express
1 Silvyn rd
Redcliffe
(cnr anzac ave diagonally across from Mcdonalds.)
WHEN
October 11 from 6 pm - 8pm.
WHATS COVERED.
car security, common misconceptions, urban myths, install integrity.
there wil be some examples of this on a screen on what a proper install should look like and of course the horrible ones. i will pick off a car just to show how easy it is to take on of these.
V35 sedan owners are welcome to attend.
if you are silly enough to leave your car unlocked and in my sight it may get used as an example as well.
if you have an interest in this post below. if i know you personally ten a yes or no is enough.
IF I DO NOT KNOW YOU:
I want yor name, car rego and phone number pm'd to me. that way i have a register of who was there.
see you there.
I'm in (if allowed). Sending a pm now :)
of course you are allowed :)
its not a mates only thing. The last line is for my reference and if something goes missing in my shop OR off someones car.
Oh, I actually wrote that because I thought I read somewhere that only approximately 20 cars could come, or somethIng along those lines. :) all good, cya there!
Edit: found what I was talking about in the old thread.
"i do not have a set limit on these but i do have fixed space so 15-20 people is all i can hold. "
Edited by Bergo
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
