Sorry I haven't had time to update.
BC's are sold.
Dual din stereo surround sold, still have the triple gauges though.
Attessa unit sold to Ironpaw. ^^
Attessa relays sold.
Scotty, I'm after the cover for the fuel pipework under the RHS wheelarch, a couple of load area tie down hooks, and the red plastic cover over the Pos battery terminal in the engine bay.
Feel free to PM if they're available.
Cheers, Dale.
The cover should be fine, I haven't got into the back to check anything as Craig threw his ARX interior in the back and wedged it in tight. :P
As usual the red plastic cover for the positive terminal snapped off at the hinge the other day.
Did this car have a different ecu? Nismo, impul.....?
Not sure yet Craig. I doubt it.
If it did you would have snatched it before it came down, wouldn't you?
  • Like 1
How did the rear subframe fair from the rear end damage?
The non Hicas subframe seems perfect. I removed the suspension today and it looked fine. It was hit very high in the rear, at glass level. I think it was a 4x4 or truck bull bar. The Attessa unit was unharmed.
No great rush; red plastic cover makes me sad though. :/
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
