Hey all,
Pulled off my wheels to re-paint the brembos on my 33 GTR and the front driver has a a couple cracks in it.
Wasnt until i started spraying them red that i noticed the cracks. The black covered it up.
Has any one had this happen before?
Whats the chances of getting a single caliper?
Anyone know where to start looking?
Are any other models or different cars even that run the same brembos??
Is it just heat that causes it??
Thanks
https://www.sau.com.au/forums/topic/411453-craked-brembo-caliper/
As above, looks like it has a fair few layers of paint on it. And usually it's the old paint that shows cracks like that.
The second pic is where the two halves of the caliper are joined together, not a crack :)
not a good result.
i suggest that alarm bells should have been ringing when the bleed nipples, pistons and piston seals were all covered in that shit red paint.
bin.
Edit: did they come on the car or did you buy them. There's a fair amount of meat removed - i personally wouldn't be confident continuing to use these calipers.
Oh no they were black. I didn't notice until I started rubbing back. Again didn't take any notice. I sprayed it red and because of the colour saw the cracking lines. So rubbed it back to metal to find body filler. Got out the hammer and screw driver. Gave it a hit and out popped body filler.
Have since finished the other 3 and they are fine.
Very weird.
Now I have to find just one!
yeah bummer - that's really weird that only one of the front pair is like this.
don't know how you'd go with getting a single; you might need to get a pair and keep the other one for parts if necessary.
plus if you are going to repaint then you don't need something that looks great - maybe you can save some coin there.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
