Newcastle/central Coast Cruise To Broke And Back! 2/12/12
150km from my place to the meet point. I'll drag my ass up from Sydney again. Pencil me in.
Nice work! I like the fact you guys are motivated to come all the way up just to cruise :thumbsup:
And and BTW, fuel pump is coming out on Friday too!
  • Replies 177
Sick dude! Memory serves me correct that's the Bosch one? Almost direct fit replacement yeah?
Hit me up with a PM with how much you're looking for and I'll buy it. I was going to buy a brand new one this week but I think I can wait.
Sounds good
At least the return trip will be a lot shorter for you
And second in line for fuel pump if you don't take it
Yeah Bosch 044 but it is not a direct fit, does need mods..... Will let you know once its out of the car :yes:
You'll also have to give me the hot tip on what mods are required as I'm useless with most things.
I might come if I'm not working
I might join you for the cruise up from Le shire
Yeah dude that would be sick! There's fair warning between now and the cruise, gotta roster that shit off if possible!
ATTENDING
Ruxis- R34 GTT
GTR34A- R34 GTR
mjh- R34 GTT
34geeteetee- R34 GTT
Chookie- R34 GTT
Humbla- R33 GTST
BenRthirtyfour- R34 GTT
Gtraaron- R33 GTR
Tank- R34 GTR
Beenowened- R33 GTST
RB25 SKYLINE- R33 GTST
Chad_- R32 GTR
Wrximposter- 06 WRX
Danmc- 06 WRX
KURTIS34- More kw the mat 34 GTT (hehe)
The_wolf- n15 sss
WAGON_BOY- Stagea
FeZ25- R34 GTT
MAYBE
TimmyMA70- SSS PULSAR
Luke Gtr- R32 GTR
Levinboy- R33 GTR
will be very impressed with that effort levinboy
18 people confirmed so far in less then a week, my god!!
keep em coming!!
Meh,i live 4 hours away,still comin.
Can't wait.
I spotted your baby 10mins away today :ph34r: could see it from the main road as I passed :D
There once was a wombat from Broke
Got stoned on a bourbon and coke
Became smashed by a sump
Reduced to a lump
Now 10 of his kids are provoked
...might play safe and come in the foz
Haha good point terry.
Did have a roo jump infront of me while checking out the route, I've talked to guys at work who live there and they said there not very common there.
From that we will be leaving big gaps in-between each other
Aww I want to see your N1 again :(
haha kidding the forester is fine :)
Well all the boys on the coast we need to make a meeting point for the trip up the cruise start point, i was thinking Ourimba rest area just b4 u enter the F3 or if we go from Kariong, the same carpark the meet was at last time, what do u guys think?
Guest
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
