  • Replies 48
ahhh :whistling:
Asus Transformer Infinity - 64gb
http://eee.asus.com/...finity/features
So far super happy with it. Fast, lots of apps (tho Polaris is not an alternative to Word or Excel - and they aren't available in the android store (yet hopfully) basic formulas work ok but the graphs dont link well at all).
Widgets work quite well, all screens can be customised with widgets and app icons combined. Not that i'm going to, but it had standard functionality to load customised ROM's on (a ROM is a different.custom operating system i assume).
The dock is very handy - full keyboard with all the required shortcuts to navigate around. No need for a mouse being touch screen, only gadget i will but is a stylus at some point to use with intricate photoshop editting. Seems to play a good variety of video formats (avi, mp4 etc.) and music formats (mp4 and m4r?). Has true GPS, and 3 GPS navigation type apps re-loaded for some reason. One is a handy 'whats close by' app for finding restaurants/shops/etc. close by.
It has a camera - that is all. I'm not going to use the fkn thing and look like a cock head.
Super thin and light - will be alot easier to cart around on my upcoming holiday overseas than the massive heavy laptop (which never seemed that huge until now).
Downloaded the Photoshop Touch app yesterday - not had a chance to use it yet but it appears very powerful. Going to hunt down a RAW image app also. Both apps combined means i can use the tabelt whilst overseas to review and edit up photos taken :)
Edited by barraspalding
And its quad core, 1920x18080
Nice touch the bootloader being unlocked
Yeah roms contain all the files like a win xp, 7 8 disc would hold when you load your OS all custom roms are a little bit different
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
