Hey guys, just got a problem hoping someone can help me with it or point me in the right direction to get it fixed.
I have a rb20 with a turbo from hypergear, nistune ecu, injectors, front mount, full exhaust all the usual mods, when i rev it out from 1st gear to second gear in high rpm it bogs down/lag and then the power kicks back in once ur in second gear, its almost feels like u slam on the brakes inbetween the gear change. Uts getting really annoying and i dont know what it could be, i thought it could be the BOV, coz i had it blocked off so i thought it might have been the air going back out the turbo slowing the wheel down but unblocked it and it still does it, i also have the pipe that comes off the BOV just pointing into the engine bay, not back into the intake, its still a stock BOV aswell.
If anyone could help me out that would be much appreciated.
https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/
Do you mean where the plumb back pipe connects into the intake pipe, it's not connected?
So you are sucking air into the turbo through the hole in the side of the intake pipe?
Air that is unfiltered and also not measured by the AFM?
This would be a problem me thinks...
The Bov plumb back pipe, it's not attached to the Bov right?
Is the other end still attached to the intake pipe between the AFM and the Turbo?
Have you blocked any of the open pipes?
Its just the normal stock BOV and the pipe that from the trumpet bit of it just goes to no where to the engine bay, it used to go to some pipe which took it back to the intake for the emision reasons, but since upgrading to another turbo i had to get rid of all that so that bit of pipe just vents to the engine bay, and no other pipes have been blocked either
Blame the tuner :P
Waiting on NIStunes reply. They emailed today. Hopefuly have a few answers tomorrow
send it through if you need a quick reply, have the tuning lappy at home tonight.
I also had this problem on the R33, happens the air doses backwards onto the AFM. It was fixed by relocating the afm into the cooler piping.
Definatey seems like the same issue, and to clear things up its not a lag issue, its a hesitation
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
