after hanging shit on drunkan for years i decided to buy one of these for a laugh.
anyway it has a lunched motor, and i have an rs260 frontcut in my shed that just wants to go into it to make it a little bit more fun.
so ill slap the conversion it in over the next few weeks and have some fun.
any tips would be appreciated on stuff to look out for during the conversion.
bought off a local sydney sau guy.
https://www.sau.com.au/forums/topic/413114-bought-an-rs4/
  • Replies 58
haha, welcome to the club fatz
also, you have a lot of project cars
my tips would be:
use the 34 clutch master (without the gtr/260rs booster) and you don't have to recess the firewall
get a manual cradle so the front and rear tracks are the same, i think gtr may also be the same or s14
also, maybe take the auto radiator out and put a 33 one in to piss off the heat exchanger
oh, and check for rust under the wing mirrors
and if its got only 1 reverse light check for epic rust
Edited by pipster11
https://www.sau.com.au/forums/topic/413114-bought-an-rs4/#findComment-6610916
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
