got a few parts left over kicking about, as follows below
pics on request
r32 aircon compressor n mount $80
r32 a/c condensor and most lines $100
r32 gtst metal fuel tank $100
r32 gtr/gts4 atessa....sp? reservoir and lines $40
r33 hicas unit $50
r32 gtr rear sway bar $100
rb20/25 push type excedy heavy duty button clutch $500
near new 500-1000kms
3" split dump/front all in one with $50 worth of heat wrap $150
located VIC -SE
pm or post
Edited by Dan_J
good condition i presume, was removed from a wreck, not due to being faulty
also added
gtr/gts4 manual gearbox cross member and mount $80
rb20 auto tranny Free
might be the 5psd as it came out of a cefiro
s13 sr20 auto tranny free
bump
clutch kit set me back $670 few months back
pics on request
also got
rear s13/r32 JIC coilovers -$150
height adjustable not damper with helper springs, one is leaking
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
10 AN turbo oil drain fitting from kando - $40 ------ $50 posted Aus wide
, awhile back bought the wrong one so got this laying around.
suit high mounted turbo or similar with stock oil drain bolt / hypergear.
from the thread start to end its 36cm, 32cm not including the thread on the nut thats crimped onto the braided line
you need to get an adapter to bolt onto the block to 10an
look like this but longer and no barb ( do have one to suit if needed tho)
$%28KGrHqZ,!qgE-y+Ppm%29yBPy+-ElHYw~~60_
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
