Import Monster Sauvic Deca Motorkhana - 8Th December 2012 - Entries Open
  • Replies 195
Posted Images
On the entry form under the 'Car Details' section, it asks for the number plates registration number and my car won't be registered until late next week if not the week after......
Can i write 'TBA' until i get my number plates?
Nah of course not lol.
Ill be driving the 33! Frieken BOAT! Flying the MARINE FLAG this time!
Lucky you got your boat licence for the summer!
I'm planning to be there but cbf driving this time.
haha we'll see. The other thing is it's summer, and you know what that means. Boat time!
boat time eyy, so what R33 are you driving?? :laugh:
