Import Monster Sauvic Deca Motorkhana - 8Th December 2012 - Entries Open
  • Replies 195
Posted Images
On the entry form under the 'Car Details' section, it asks for the number plates registration number and my car won't be registered until late next week if not the week after......
Can i write 'TBA' until i get my number plates?
Nah of course not lol.
Ill be driving the 33! Frieken BOAT! Flying the MARINE FLAG this time!
Lucky you got your boat licence for the summer!
I'm planning to be there but cbf driving this time.
haha we'll see. The other thing is it's summer, and you know what that means. Boat time!
boat time eyy, so what R33 are you driving?? :laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
