yeah its tricky to tell without the falt edge hey. i was surprised cos it didnt even look convex but it was.
all you have to do is get the actual mirror assembly out (the plastic bit with th glass in, not the housing) and just take it to your local glass shop, drop it off and give them $20 half an hour later and refit.
not sure about the scratched windows, but i'm sure they can do something, just ask and see what they can come up with.
  • Replies 145
Posted Images
hey steve,
yes WA regs require a high mount stoplight be fitted if the car was manufactured after June 1989 (i think). You dont always have to put one in, as alot of cars already have them on (a mates oct rx7 had one built into the tailgate).
if you need to put one in, just goto bigw or kmart/supercheap etc, buy a nice slimone that can mount to your inner windscreen. mount it up and run the wires down through the trim and tap you brake light wires.easy!
Hey Guys
Just bought 32 gtst type m..december build so like everyone is is right at the back of the que to get my car over here!
Anyways, i have been reading about compliancing and its all good stuff..cheers guys!
However i hear in SA they get pretty strict and are pretty trigger happy..
so just wondering if anyone needs to know what to get done in SA and if i can do most of it myself and get an engineer to sign it off
cheers
For Tyler and PHATR32, DRIFTT knows more than me but i'll put up what i know you need
*you NEED a restrictor in the filler neck (LRP still sold here)
*you may/may not have to change front belts (look for the label as mentioned earlier)
*you will have to change rear belts (if you have them/are going to keep them) they are most probably going to be just lap belts, requires lap-sash (goes across your chest)
*you may not have to change your *drivers side* mirror, depending on whether it is convex or flat (convex=must change) passenger side can remain convex.
*you MUST fit side intrusion bars if not fitted from factory - some 89 models have them factory, but i think most don't? (Skylines def don't)
*you need to securely attach a tyre placard to the vehicle (door jamb or under bonnet usually) and also an "unleaded fuel only" sticker somewhere near the filler.
---EDIT---
*you must fit child restraint anchor points if the car is capable of carrying a baby capsule (pretty sure 2 seaters arent allowed to, so you dont have to fit them) Most skylines have them done through the rear parcel shelf.
*you'll also need a high mount stoplight if your car doesnt have one. If theres one in the spoiler , upper tailgate, or inner windscreen that will suffice, otherwise you'll have to mount one (easy) see earlier post
i know i'm forgetting some things, and this is only from personal experience...
Phat if you want to buy tyre placards, go and see Paul at Autoworx in Wangara, he's got them pre printed ready to stick on. Or you can just make them yourself - get someone on here to give you the figures on it (i havn't got one sorry) then make one up in word, photshop whatever, print it out, and contact it onto the car if you cant find another way to stick it on.
one thing that hasn't been mentioned here is the side indicators that are on the guards. My last 32 GTS-T had compliance indicators. Do they still need to be installed? I saw a recently complied '89 R32 GTR and that didn't have any on the side.
cheers for that blacky.
Just a few quetions for anyone in the know,
Q1:with the child restraint attachments, does each rear seat need it's own attachment or do you just need one for the one seat?
Q2: the a/c controls in my r32 have been moved to the dash in front of the passenger seat, does anyone know if this would need to be moved back to stock position?
Bought some r32 anti-intrusion bars on friday. Was $130 for both (the car is a two door), which includes the actual bars and the brackets that weld to either end. Very good buy, if i get it ready for welding myself, should have intrusion bars installed for $250 max. Sweet!
You'll need them for both seats
Holes are already there but need to be drilled through the parcel shelf.
I also used a couple of spacers to raise them enough to clear the original speaker
covers.Make sure you buy the "late model"? restraints that have a provision for
a clip.When you go to buy them there is 2 types.
As for the a/c as long as the engineer signs off on your car with them there you should be fine.
Hope that helps
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
