  • Replies 55
  • 1 month later...
BUMP this up. Sorry for no replys everyone. I was overseas for a month or so. I'll post up an updated list of what is left later on today.
Cheers
Colin
Snorkel is all f**ked up sorry.
Updated list.
94 GTR
Unopened 26
-7 Turbos with actuators 20,000kms old $1000
550cc denso injectors $450
R34 GTR Dumps $250
Front pipe 68mm ID (i think) $350
Catco 3inch cat $100
Fujitsubo catback $150
NPC Organic Clutch pull type. <5000ks old $700
Turbosmart Boost tee $75
Nistune R32 GTR Ecu $300
Yellow Jacket Coilpacks $300
PWR Oil Cooler 22row? and trust oil relocator kit. Will need some hoses. Never fitted to car. $500
GTR Gearbox $500
Walbro fuel pump $100
GTR Seats good condition no tears or rips $600
Rear seats $?? Offer
Full interior available
Suspension available but will need to check what survived
Sumitomo calipers freshly rebuilt $350
RDA slotted fronts and Brakes direct rears brand new with QFM HPX pads $700
HEL Braided lines brand new $120
Diff, transfer case, hubs, axles, tailshaft etc all up for grabs cbf putting a price on it but you get the idea.
Have all of the stock parts for things that have been replaced ie stock suspension, stock turbos, stock injectors, coil packs, exhaust etc.
Full rear cradle, diff etc has been sold aswell.
Edited by Beelzebub89
colin, seatbelts ? all still retract?
door and rear side panels? condition?
can pull all of it when ever you want.
how much of the airbox survived btw?
Only the snorkels got ruined, airbox is still fine. seat belts all good. Panels are we talking door trims or exterior panels? Most of the exterior is stuffed.
Hi just want to know if you would sell the left rear quarter Cut if that's still in good nick ?? cheers
Claude
Quarter cut as in exterior panels? I've got no means of making any cuts that extensive atm sorry.
How old are the injectors?
I'd had them on the car a year or so, bought them second hand. Did 15k kms on them maybe? not even that much I think. No idea how many ks they've done before that, pretty new i think when i bought them.
inside panels. give me a call/ text with a price for the belts,inside panels and airbox. I hav the rest of it already. have money handy.
in regard to panel cuts , i can help there if the buyer needs it. I know where the seams are.
Items sold:
Turbos
Dumps
Rear seats
Seat belts
Rear wiring harness
Door cards,
Door rubbers
G sensor
Attessa & hicas control modules
Air box
Indicator stalk
Still lots available.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
