  • Replies 55
All gone sorry mate.
Stuff remaining is as follows
Stock motor - $3k
NPC Organic clutch, pull type. 3000kms on it. $700
PWR 21 Row Oil cooler and trust relocator kit $500
Stock R32 GTR Wheels $500
Front pipes (trust copies i think) 76mm id $350
Front Pipes 70mm id $250
Fujitsubo catback $200
Random catback $200
Nismo Strut braces front and rear $150ea
550cc denso injectors $450
Nistune ECU $300
Standard R32 gauges and dash cluster $400
Dash $200
Roof Lining ???
Sold Items
Door cards
Gearbox
Rear cradle assembly. Everything gone incl diff halfshafts etc
Brakes
-7 turbos
R34 dumps
All seats
Rear parcel shelf
Rear wiring harness
Seatbelts
Welcome to ask for things but the way things are at the moment I'm not wasting time stripping A/C vents off the car to post to Sydney or some shit. If you want misc items you're welcome to come and visit and pull off what you need. I want to get the big stuff gone so I can box up the rest and f**k the shell off.
Cheers
Colin
  • 6 months later...
Hi,
Is the Fujitsubo exhaust still available? Can you confirm it's 3.5" all the way, not 80mm stepping up to 90mm or something like that?
Any pics or model number so I can see what it looks like?
Thanks
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
