As suggested above, you should try to find all your own parts and save some money as much as you can. Use eBay to find all those cheap copy fuel pumps, plenums and exhaust manifolds.
That way they can charge you the time the job takes, plus the time to tidy up or repair the cheap part, charge you to replace the part when it fails and charge you all the labour again to fix it.
You'll save heaps.
You'll save heaps.
:yes: best post ever
You'll save heaps.
This !!
Do it once, do it right !
It will cost you but it will be done properly.
You'll save heaps.
yeh no that's not goin to happen build it proply the 1st time.
Excellent to hear.
If you find cheaper prices for parts they are offering, maybe ask them if they'll match it.
I don't doubt the parts list will be appropriate for the power you want to make but there are a lot of things involved in a build like that. Do you really need that plenum?
Do they do all their own engines or are the built somewhere else? What kind of warranty do they offer on their work (inc the engine) if any at all.
What kind of gaurantee do they give that you'll make the quoted power. It's a lot of money to spend only to fall short of your goal
They recently did a nitto rb32 build for a customer with an r34 gtr and oh my God so so much power..best part was customer had unlimited budget so they were able to do things properly.. Car drives like stock but when you floor it, destroys the road under it haha.
I thought you had a HTA3586?, anyways cams are to big for a start... looks like
a lot of money for f**kall gain..you seem to like to spend money for no apparent reason(and no i am not having a go at you
just having cars and mates with similair setups..thats total and utter overkill for the turbos you want, K.I.S.S, is what you want to do
quality parts that will do the job asked with overdoing/overkill them...you will spend twice as much for no reason or reliability..
You REALLY need to decide what you want before you start...
cheers
Darren
Edited by jet_r31
You'll save heaps.
hahaha, thats doen't happen much..lol
cheers
darern
Just a quick one....I was reading through the list again and noticed you are only using 1000cc injectors and a pump that flows 400 L/min @ 60psi.
That pump will just scrape in at 650hp at the wheels on E85 so you should be ok for flow there but the injectors are really only good for 550hp on E85 so maybe you should ask them about 1600cc or 2000cc injectors instead?.
You can just bump the rail pressure up to make the injectors flow more but the pump will then flow less and it brings it closer to your 450kw margin. Just some food for thought anyway
to be honest I also thought they where on the smaller side if and when I Desideed to go E85 so yes bigger injectors I will get Edited by MRHD66
Honestly....I would develop a fantastic relationship with a workshop and get them to build the thing. Price sounds about right but its the things you can't put a dollar value to that are important. You take $1000 off the price somehow and eventually you will be paying $5000 back to them or someone else.
If and when? You're going to make 600hp at the wheels on 98? I applaud your courage
Can be done. Much safer on E85. The cubes should help but still.....
You'll save heaps.
lol, so glad I'm not in the automotive industry anymore. People think you're ripping them off if you charge them for the time you spend sourcing parts. Then they say you did a shit job when the parts they supply that you've never used turn to shit, assuming they even give you everything you need. They also expect you to take up the warranty with the companies they bought the parts from :thumbsup:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
