Hey guys I am located on the Gold Coast, willing to post items at cost or pick up and currently have the following for sale;
R32 GTR (Will fit GTST) Aftermarket vented fibreglass bonnet, It is ADR approved and comes with approval documents, It has been fitted with bonnet pins but has the catch part and will work with r32 gtr standard bonnet catch system. The holes can easily be covered with a plate or filled in, or ready to run bonnet pins, can supply bonnet pins if req. It is professionally painted in jet black, no scratches painted underside aswell.
Bonnet$1000, Bonnet Pins $10, Bonnet hinges $40
R32 GTR Projector style Headlights L/H and R/H, also R32 GTR Indicators (All will fit GTST as well) All in perfect condition lenses mounts everything and comes with bulbs and rear covers etc.
Headlights $200pair Indicators $100pair (RH indicator has tiny crack, barely noticeable)
R32 Side Mirrors Black, R/h has slight damage as seen in pic, LH is undamaged $60
R32 GTR Passenger seat Immaculate condition, with rail, all movements working perfectly $300
Also have a std R32 Gtst drivers seat laying around in good condition for $50, and GTR rear seats in perfect condition for $120
Nismo Dash Cluster R32 GTR (320km/h and 10000rpm) (Will fit any R32) Immaculate condition with only just over 40000kms on it. $350
Momo steering wheel in perfect condition, also have an immaculate genuine horn button to fit. Steer wheel $150, Button $30
R32 Gtr Front strut Brace Avg Condition $120
Names Johnny I would rather you call or txt, otherwise please PM, avoid posting on the topic thanks
0414596256
https://www.sau.com.au/forums/topic/413850-r32-gtr-parts/
More parts listed;
R32 GTR genuine Front Grill Very good condition $150
R32 GTR genuine front bar very good cond $300
R32 GTR genuine front lip $150
R32 gear and handbrake boots white with nismo imprint $50
R32 gtst A/C digital control unit $60
R32 GTR/Gtst centre console plastic surround $50
HKS intake kit for GTR with 3A racing pods only used for 2000km $200
Alloy 54mm radiator to suit R32 GTR/Gtst with silicone hoses only used for 2000km also have radiator brackets $200
Autometer Tacho with shift light $20 perfect working cond, with all brackets wiring req.
Plenty more bits and pieces from $20, adjustable arms etc stripping whole car including built rb26 with hks 2530's, PM or txt/call for further deets or other parts
Edited by slidinr32gtr
https://www.sau.com.au/forums/topic/413850-r32-gtr-parts/#findComment-6633596
Gear and hand brake boots sold, as well as just the speedometer dial in the cluster, rest of cluster still for sale for $40, More Parts FOR SALE
Pwr FC hand controller $300
Power fc d-jetro map sensors and loom $300
Intercooler 600x300x100 $200 3" inlet/outlet big hks style tube and fin
3" cooler piping from twin turbo pipe to plenum $200 incl hose clamps and silicone joiners
Trust Type R BOV $300 stiff spring type
R32 REO $50
R32 Overflow bottle good cond $40
Door cards $60 pair
PM or txt for pics
https://www.sau.com.au/forums/topic/413850-r32-gtr-parts/#findComment-6636473
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
