All the parts you can see in the pics are for sale. some even free. These are the only parts i have left as the rest of the car has been sold so dont ask for something you dont see. I'm sorry about my previous thread but there were too many people asking for stuff i dont have and i only just finally got my mates camera so i could take photos so here they are. if you want something that you see here pm me with the part/s you want in the subject so i dont have heaps of emails just saying 'parts' it makes things painfully slow as i am only on a modem connection and it takes so long to open pages. Also include an offer in your pm. Thanks :D
badges - only the gt badges are still available. the front badge is sold
battery - only done about 5000k's with this battery
sold - boot trim jack cover
standard cat-back zorst - very quiet.
sold - front left guard. not a ding or scratch on it.
various bits - battery bracket, radiator seats, etc
ecu - stock
https://www.sau.com.au/forums/topic/41389-r32-gtst-parts-for-sale/
dash cluster
dash cluster surround
glovebox
speedo - 72472Kms
steering column surround
passenger seat
rear seat
bracket covers for front seats - the bits that cover where the seats bolt down
steering wheel - original - good cond.
SOLD --> vents
headlight - passenger side (broken) - free - come and get it if theres bits on it you want.
reverse light - driver side
spotlights - off m-spec front bar - including surrounds
sold - indicator - front - drivers side
headlight - drivers side
indicators - both quaterpanels
rear lights - passenger side
sold - indicator - front - passenger side
dash cluster
glovebox
speedo - 72472Kms
passenger seat
rear seat
various air vents from dash
Have you still got the steering wheel if so how much and will you post?
Hey Mate,
Can i get a Break down of Each Individual price on the following items
front left guard
Steering Wheel
indicator - front - Driver side
I have the money ready to purchase these.
Your welcome to PM me if you want to
Hey sinisteR32,
If you still have the headlight - drivers side can I give you some $$ and get it shipped to Sydney? I'm also after a drivers side blinker. Let me know what you can do.
You can call/SMS me on 0413 980 100 or email me at [email protected] if that's cool.
Thanks heaps for your time mate.
headlight - drivers side - free - come and get it if theres bits on it you want.
