Bruno Senna has walked away from Formula One, signing a deal to race for Aston Martin in this year's World Endurance Championship.
Senna will share the #99 with Fred Makoweicki contesting the full Championship while Rob Bell will join them for the Le Mans 24 Hours and the Spa 6 Hours.
http://www.planetf1....-farewell-to-F1
Marussia have confirmed Luiz Razia as their second driver for 2013.
http://www.planetf1....a-confirm-Razia
Day twoTimes
01. Romain Grosjean Lotus 1m18.218 95 laps
02. Paul di Resta Force India 1m19.003 + 0.785 95 laps
03. Daniel Ricciardo Toro Rosso 1m19.134 + 0.916 83 laps
04. Mark Webber Red Bull 1m19.338 + 1.120 101 laps
05. Nico Hulkenberg Sauber 1m19.502 + 1.284 99 laps
06. Lewis Hamilton Mercedes 1m19.519 + 1.301 15 laps
07. Sergio Perez McLaren 1m19.572 + 1.354 81 laps
08. Felipe Massa Ferrari 1m19.914 + 1.696 78 laps
09. Pastor Maldonado Williams 1m20.693 + 2.475 71 laps
10. James Rossiter Force India 1m21.273 + 3.055 19 laps
11. Giedo van der Garde Caterham 1m21.311 + 3.093 88 laps
12. Luiz Razia Marussia 1m23.537 + 5.319 31 laps
http://www.planetf1....-Way-On-Day-Two
http://www.planetf1....ictures#photo=2
good job mang.
problem solved?
btw.
Lewis Hamilton has billed the brake failure that caused his Jerez crash on Wednesday as "all part of testing."
Hamilton's first official day in his Mercedes W04 came to a premature end when, just after 15 laps, he suffered a rear brake pressure problem.
Although using the front brakes to slow the car, the 28-year-old was not able to prevent a crash, hitting the tyre barrier at the Dry Sack hairpin nose first.
Mercedes later revealed that the problem was caused by a hydraulic brake line connecting to the right-rear calliper.
http://www.planetf1.com/driver/18227/8476009/Hamilton-Better-now-than-later
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
