Robert Kubica will make his return to competitive racing later this month after it was confirmed he will race in the WRC2 category of the World Rally Championship.
The FIA has given Citroen permission to use a paddle-shift gearbox on the left side of the steering wheel, with its change of speed to match that of a conventional gearbox.
http://www.planetf1.com/driver/18227/8542021/Kubica-to-race-in-WRC2
Formula One supremo Bernie Ecclestone believes a 22-race calendar is within the realms of possibility and is also eager to have stopover in Cape Town.
http://www.planetf1.com/driver/18227/8541693/Bernie-eyeing-22-races-and-Cape-Town
Drug testers have swooped on the homes of several Formula One drivers, including Australia's Daniel Ricciardo, in surprise early morning raids.
Ferrari's dual world champion Fernando Alonso said the testers, from the World Anti-Doping Agency (WADA), arrived at his house at 6.42am on Tuesday.
New McLaren driver Sergio Perez confirmed he had endured a very early morning wake-up call as the result of a surprise urine test.
And Torro Rosso racer Ricciardo tweeted that he "Got drug tested early hours this morning."
He said: "All of a sudden pissing in your own home becomes difficult with someone staring over your shoulder."
Drug testing in F1 is relatively rare, but it is not the first time officials have made surprise visits to drivers' homes.
In 2009 Mercedes driver Nico Rosberg - then with Williams F1 - was drug-tested by WADA while on holiday in Ibiza.
He said the agent woke him up at 7am one morning, informing him that he had been selected for a random drugs spot-check.
"My girlfriend took the call," Rosberg said. "So it was lucky that the test took place at all because she doesn't like being woken up early while on holiday."
Mark Webber recently called on Formula One's governing body, the FIA, to step up its drug testing, after a motorcycle racer was banned.
Former MotoGP rider Anthony West, who now races in the second-tier Moto2 category, was banned for a month after testing positive for the stimulant Methylhexaneamine.
Webber welcomed motorcycling's push to ensure the sport is drug-free, and called on the FIA to become more active on the issue.
"I've always been championing the idea to do more of it, but the FIA have never really been that strong on it," Webber said.
"The other drivers have never been super strong on it, so it's never really been a huge issue."
Domestically, V8 Supercar drivers will be drug tested up to three times more often under tougher anti-doping rules to be implemented by motor sport authorities, according to a Fairfax report.
Through CAMS, V8 Supercars complies with the anti-doping requirements of WADA and the Australian Sports Anti-Doping Authority.
Racing drivers have not been implicated in the recent Australian Crime Commission's investigation into drugs and corruption in sport but CAMS will review its approach to anti-doping, illicit drugs and also race fixing and corruption.
http://wwos.ninemsn.com.au/article.aspx?id=8621883
So for any of u guys who want to
Go or are on thursday. I have a spare silver gp advantage ticket.... Eg early entry, breaky and a pit walk thing!
If you want to join me and a mate for the tour and breaky let me know
$60 0400099986 to tee it up!
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
